XG-FULLHD NEC XG HDMI 1.3
Das444
Posted: Thu Feb 09, 2012 3:49 pm    Post subject: XG-FULLHD NEC XG HDMI 1.3
Hi.
I have a XG-FULLHD NEC XG HDMI 1.3 card. I'm trying to switch the card to DVI-RGB. Moving the switches up is on and down is off?
Dan
Posted: Tue Feb 14, 2012 8:49 am    Post subject:
Ive just got the same one, what do all the DIPs actually do? Mine are all down, if looking at the card with the labels the correct way up.
Aussie_Al
TV/Projector: NEC 9PG, XG1101, XG1350
Posted: Tue Feb 14, 2012 11:53 am    Post subject: Re: XG-FULLHD NEC XG HDMI 1.3
Optional switch to manual set DVI-RGB 0-255 mode (only valid when video source send DVI-RGB signal, default is 16-235 range):
SW 1 2 3 4 5
off off off off on will active DVI-RGB mode (0-255 Range)
I would have thought so too, but after just having taken a look at mine that doesn't seem the case. On the lower left side of SW 1 there is an arrow pointing down with 'ON' beside.
Mine are all down as well, as shipped from the factory. The only reference to the DIP's I found in the data sheet is what I have quoted above.
http://www.moomecard.com/index.php?option=com_content&view=article&id=12&Itemid=17
Posted: Tue Feb 14, 2012 12:15 pm    Post subject:
Bout time you made a post here... Wink
Yeah i only found that too, with no other info about the other switches.
