blanking is Red on all sides, Help! dim video on red tube
Das444
Posted: Sun Feb 05, 2012 6:10 pm    Post subject: blanking is Red on all sides, Help! dim video on red tube
This is what I have.
Red tube is very dim when playing video. Adjustment menu is bright. internal test pattern crosshair ect are dim. Any one know what could cause this?I did swap neck boards but no change.
NEC XG 1350
Dan
Posted: Sun Feb 05, 2012 7:44 pm    Post subject:
OK, as you already changed, my first guess would have been the video neck board. Since you've changed that, the next guess would be almost any board in the card cage. The AKB (auto brightness) control is set by the system board, but can also be affected by any other board in the set.
I had one of the video processing boards smoke a transistor once in a set, causing very dim blue (I think), on signal and menus. About all you can do is swap them. Also try going into the color balance menu and see if it brightens up. that would possibly indicate a system board glitch. Doing a new signal entry might solve it as well. Also try turning the AKB setting on and off.
Posted: Mon Feb 06, 2012 4:49 am    Post subject:
What happens when you press the KELVIN button? Ive got a very simular issue with my PG.
Posted: Mon Feb 06, 2012 5:00 am    Post subject:
Laser beams shoot out Laughing
Posted: Mon Feb 06, 2012 5:53 am    Post subject:
Then what happens? Laughing
Posted: Mon Feb 06, 2012 6:05 am    Post subject:
Then the friken' sharks show up Laughing
Posted: Mon Feb 06, 2012 11:01 am    Post subject:
HAHAHAHA!! Youre a clown Wink
Might be able to cancel my red dim issue too by the looks, im in the test phase, but thus far, success seems to have come in the way of replacing almost all the caps on the video output board...
Das444
Posted: Mon Feb 06, 2012 12:05 pm    Post subject:
Case,
Blue and green are working fine I'm going pull some boards today and have a look. (If I only knew what to look for).
Dan
Posted: Mon Feb 06, 2012 1:52 pm    Post subject:
Yeah Dan, my issue will quite likely be different to yours, however when i was to press KELVIN on my remote, my RED would then brighten up to be spot on where it should be, then in a while, it would be too bright.
If i left AKB turned on, it would be perfectly fine, so i was wondering if yours follows this trend or if it remains constantly dim.
I just replaced almost every capacitor on the video output board ( most of them were leaking, which they were not 9 months ago ), and that seems to have solved the issue, it is now abit brighter and has better colour than it has had for a long time.
Das444
Posted: Tue Feb 07, 2012 12:03 pm    Post subject:
Case,
I have come across something else going on here. The blanking is red on all sides not black as it should be. Could it be a focus yoke coil?
Posted: Tue Feb 07, 2012 3:00 pm    Post subject:
With no input signal are all the tubes turned fully off ?
Posted: Tue Feb 07, 2012 3:01 pm    Post subject:
No, what you have is that the black level is too high on the tube, illuminating the whole raster, along with weak video. You're seeing the whole raster lit up on hte screen, blanking won't get rid of that. I still say it's one of the video boards or a problem in the system board.
What does happen when you go into the 'kelvin' setting?
Das444
Posted: Tue Feb 07, 2012 3:19 pm    Post subject:
Curt,
What is the switch for on the side of the front yoke at the tube bell? maybe it was bumped.(when adjusting)
I'm at work, I will check when I get home.
Dan
Jeremy112
Posted: Tue Feb 07, 2012 5:14 pm    Post subject:
I wonder if our 2 problems are related Das,
You say you see red when you use blanking, I see blue when I use blanking, and the blue raster is slightly visible on my screen, and fully visible on the tube face, the red and green do not do this...
I do not use blanking for this very reason. Curt would the "Black Level" you are speaking of be the Black Bias setting? or would it be the black level of the kelvin setting?
I have done the G2 adjustments and my G2 Voltages are right where they should be, but I know that I shouldn't be seeing blue raster on screen...
Will be interesting to see where this thread leads
Posted: Tue Feb 07, 2012 6:00 pm    Post subject:
A switch on the yoke? That's asking for trouble. Can you post a pix? That won't have anything to do with the red though.
Jeremy, the black level is in a 'super secret' hidden menu, it's locked out in the reference menu. I won't give the password out for that, sorry.
THe user adjustable black and white levels in the kelvin menu allow for tweaking as the tubes wear, but if the set is grossly out of whack for whatever reason, it needs a setup by a tech.
Das444
Posted: Tue Feb 07, 2012 10:34 pm    Post subject:
Tom W
With no input signal are all the tubes turned fully off ? Yes
Curt
What I thought was switch is some adjustment. But would not move by just bumping it.
What does happen when you go into the 'kelvin' setting?[quote]
No change
Curt
 Filesize:  90.99 KB
 Viewed:  8284 Time(s)
 Filesize:  140.86 KB
Posted: Tue Feb 07, 2012 10:58 pm    Post subject:
Whatever that switch is, don't touch it! Disconnecting any yoke winding will instantly spot burn the tube if the set is on.
Das444
Posted: Tue Feb 07, 2012 11:26 pm    Post subject:
Curt
That is a pic of a spare yoke. I adjusted the red off center to show you the menu screen. When I go to any test pattern the blue and green are bright red is dim. I'm tring to give you as much info as I can so can send me what you think I may need to fix this. I will pm you with the board numbers.
The projected image on the screen
 Filesize:  168.15 KB
 Viewed:  8269 Time(s)
Jeremy112
Posted: Wed Feb 08, 2012 2:51 am    Post subject:
I understand that you wouldnt give the password out, just want to prevent people from damaging the set or what not, lol. Actually, If you are willing to assist me curt, I can post pix of my issue tomorrow morning, Ill take tube pix and screen pix.
I cant beleive the set is that far out of whack, it still looks incredible for the issue it has. Its just on a dark scene I notice it and it bugs the hell out of me. I'm sure if I can get this figured out I wont be on here asking how to do stuff much anymore, I have all but this figured out. I don't yet know if its related to the XG or a timing issue.
So just curious curt, even if I was willing to toast my XG, would you still be unwilling to give out the password? lol
Posted: Wed Feb 08, 2012 3:32 am    Post subject:
Jeremy, send DAS444 a bit of your red, and both of you are set.
Sorry, not posting that password.
BTW, DAS or Jeremy, did you guys change tubes at all, and leave the red original, but changed the G and B? Different emissions could cause this problem (mixing high and low hour tubes).
