HaydnG90
| Posted: Fri Jan 27, 2012 6:28 am Post subject: Question for G90 owners |
When you shut the pj down do you continue to see a glow for about 5-10 mins coming from the green tube, but not from the red and blue tubes? Just wondering if this normal for the green phosphor.
| Posted: Fri Jan 27, 2012 8:35 am Post subject: |
My G70 does the same thing. Regular green phosphor just has a much longer decay time than the red or blue. Hence, the need for P43 fast refresh green phosphor for stereo 3D applications. The side benefit is higher light output.
| Posted: Fri Jan 27, 2012 10:04 am Post subject: |
All 3 CRTs i have here do that too. Not as much on the NEC PG, but certainly on both of the Sonys, its very obvious. I was under the impression it was to reduce the flicker at lower refresh rates.
