G90 Setup Issues - continued....
RickNa
Posted: Wed Jan 25, 2012 11:48 pm    Post subject: G90 Setup Issues - continued....
Trying to get the final touches on setting up my G90.
Background - new red and green tubes, old blue tube to be replaced
The main issue I have is having the unit remembering and applying the settings to my inputs. I believe I am following the manual correctly but it seems I am missing something.
I go through all focus and registration procedure on Input 1 with no active input present, as the manual states.
I save all changes as I go along. At the end of focus and registration, I do a "hard" save by holding the memory key down for 5 seconds and specifying focus, then registration.
Now, when I put a source to my inputs (DirecTV through a scaler to Input 1, and BluRay via HDMI to a Moome card on Input 2), none of the saved focus and registration gets applied. I have to go through and readjust everything while the inputs are active to get them to remember. And when I go to standby and back, those inputs still need to be tweaked some.
Can anyone tell me what I'm doing wrong here or should this "just work". I have tried changing the video memory assigned to the inputs but it doesn't seem to pick up the original convergence work. The whole video memory/input memory descriptions in the manual are tough for me to grasp, so I thought I'd see if anyone who converges these boxes regularly has any advice.
The other issue I have is getting the colors right. Is this because I have the one "weak" blue tube and two new ones? It seems, for example, I cannot get the amberish color when I compare my plasma showing the same thing as my G90. I've tried to tweak the gain and bias but no combinations seem to work and I go back to the stock 6500 or 9500 settings, which also don't look correct on screen.
Any info would be appreciated.
Rick
HaydnG90
Posted: Thu Jan 26, 2012 3:54 am    Post subject:
Sounds like a dead DALLAS chip. Is your's original to the pj? If yes, then that's the most likely explanation why your settings aren't being retained. The internal Li battery is rated for 10 yrs of life.
Posted: Fri Jan 27, 2012 4:33 pm    Post subject: Re: G90 Setup Issues - continued....
This sounds correct really. The first setup with no input is the baseline, but each input and rate needs to be setup individually. I would suggest turning the video memory to off. Then allow the G90 to automatically assign memories for each input scan rate. The G90 has memories 1-12 preassigned. So your first scan rate to save will go to memory 13. I would delete all your memories from 13 up and start over.
I usually skip the no input setup to start, and actually do 1080p 60Hz first. When you are done with 1080p 60Hz hold the save button for 5 seconds and save the geometry and focus. Then do a quick save and it will save to memory 13. After that go through all your input scan rates and finally setup no input if you want to (this only will make the menu converged when you have the projector on with no input).
You are doing this totally wrong. Bias and gain are for grayscale calibration, not color. You don't need to adjust color at all on your G90 as it is running RGB already and it does not use a color decoder. Look at gray patterns when adjusting bias and gain to make it gray.
And how do you know your PLASMA is even correct? Most digital consumer sets are VERY over saturated out of the box. Without test equipment you have no idea where it is.
If you want to adjust primaries on a CRT with respect to saturation there are two ways to accomplish this. If your primary is over saturated you can use a digital CMS (such as is found in a Radiance processor) to tone down the saturation. On the G90 blue is perfect so needs no adjustment. Red is over saturated so a digital CMS can help fix it.
Green however is under saturated. The only way to increase green saturation is to replace the C-Element with a darker green unit as is found in the Marquee projectors that are color filtered. If you need a green C-Element I have them for sale.
Kind regards,
Last edited by CIR Engineering on Fri Jan 27, 2012 7:50 pm; edited 1 time in total
RickNa
Posted: Fri Jan 27, 2012 5:53 pm    Post subject:
Craig,
Thanks for the very detailed answer and "demystifying" this all for me. I will follow your instructions on the convergence (nice to know I was in the ball park!). And thank you on the color, I suspected as much on the gain and bias and you are right, the plasma probably isn't a good benchmark.
I'll report back in a day or so and let you know how it turns out.
And as far as the Dallas chip, it would appear both YA boards have the failure-prone chip, I'm working that problem separately.
Rick
HaydnG90
Posted: Fri Jan 27, 2012 5:57 pm    Post subject:
The DALLAS chip and the IC421 (doomsday) chip are completely different. The former sits in a socket on the YA and is user replaceable. All the calibration settings, timer hours etc are stored on this chip. If you have the original chip now is the time to replace it even if you think the Li battery is good. You're on borrowed time now.
Posted: Fri Jan 27, 2012 7:54 pm    Post subject:
Haydn is correct regarding the Dallas chip. These were designed to last 10 years. Sometimes they go longer and other times they failed prematurely. You should replace yours before it dies because when it goes you will lose your serial number, hour counter, and the entire setup. I am not sure if Curt copies old Dallas chips or not, but I do. If you want it copied, you would send me your existing chip for me to back up and put on a new replacement.
Regardless, the Dallas chip is not the cause of the difficulties you are having with your setup right now Wink
RickNa
Posted: Sun Jan 29, 2012 7:41 pm    Post subject:
Thanks again to everyone's input on this. Status update, first off, the Dallas chip has been upgraded, I sent a pic to Curt and he confirmed it is dated in 2011. I went through the process, at least partially, as you said Craig and both inputs a and b are now using input memory 13 (I deleted 13-15 first). And it seems to be saving everything as expected. I'll know more when I work on it tomorrow.
For the Red focus, I am able to get all regions very crisp except the right center and the lower right corner. Now would that imply the CRT tilt needs to be adjusted slightly both in the H and V directions? It would seem that would be the only reason those two regions would be tough to nail focus-wise. I can experiment a little but if you know what direction those adjusters should be turned, that would be great.
Thanks again all, the super bowl party is starting to look alot better now!
Rick
RickNa
Posted: Mon Jan 30, 2012 1:39 am    Post subject:
Update, colors are way off. Watching the Pro Bowl, Yellow is pink, blue is greenish, green is almost greyish.
The DirecTV guide menu should be blue but is green on the pj.
Now, can I lay this off to having two new tubes (red and green) and an old worn blue tube? I will get a refurbished blue tube soon.
Thanks.
RickNa
Posted: Mon Jan 30, 2012 2:35 pm    Post subject:
Update - I looked at the colors coming in from the BluRay player through the Moome card and HDMI and they look fine. I can try to swap the two DirecTV receivers I have but can't eliminate the scaler. Not sure what's up there. I assume the input circuitry is on the BA board, is that worth trying to swap out?
RickNa
Posted: Mon Jan 30, 2012 3:12 pm    Post subject:
Uh, my bad, sorry. Loose Blue line on the scaler, girlfriend moved it to dust - doh!
Posted: Tue Jan 31, 2012 1:29 pm    Post subject:
I was going to ask if the box was analog component and if so... Smile
