RickNa
| Posted: Fri Jan 13, 2012 6:46 pm Post subject: New G90 Tube Alignment |
I've been working with Curt on this but thought I'd throw this out to the forum.
I replaced the Red and Blue tubes. I had to put the magnetic yokes from the old tubes to the new.
I fired up the box and look into the tubes, both the Red and Blue has the menu display slanted. Is this a function of the magnetic yolk not being installed in the correct position?
If so, which part of the yolk has to rotate - there are three separate yolk pieces that slide onto the tube shaft.
And can/should this be done when the box is fired up or does it have to be done with the power off and then rechecked?
Rick
RickNa
| Posted: Fri Jan 13, 2012 7:11 pm Post subject: |
I got my answer - it's the piece closest to the front of the CRT. Thanks Curt!
HaydnG90
| Posted: Fri Jan 13, 2012 7:30 pm Post subject: |
Brave man. Don't do anything today. Its Friday the 13th. Backed into my garage door this morning, so it bit me in the butt.
