| Posted: Thu Jan 12, 2012 5:59 pm Post subject: |
Because a no name brand 'melubyoulongtime' company doesn't have the visibility that the Fury does.
| Posted: Thu Jan 12, 2012 7:36 pm Post subject: |
The question is is it any good.
| Posted: Thu Jan 12, 2012 9:07 pm Post subject: |
| Nashou66 wrote: | | It is not illegal, its HDCP compliant. Athanasios | if your converting HDMI encrypted video to RGB how can it possible be compliant? I like curt's explanation better
| Spanky Ham wrote: | | The question is is it any good. | depends, you just picked up a nice sony 1272 from the local chruch auction, I bet it's plenty good.
Your a Videophile with an 8 or 9 inch set then no = no gamma, no color space, no nuttin.
| Posted: Thu Jan 12, 2012 9:21 pm Post subject: |
| draganm wrote: | | Nashou66 wrote: | | It is not illegal, its HDCP compliant. Athanasios | if your converting HDMI encrypted video to RGB how can it possible be compliant? I like curt's explanation better
Your a Videophile with an 8 or 9 inch set then no = no gamma, no color space, no nuttin. |
Simple, HDCP compliant means that it will shut off analog output(RGB) if it detects a HDCP signal and does not detect the HDCP key from the display. Not all HDMI signals have HDCP encryption, as from a PC. SO it is HDCP compliant. Its a trick of advertising, yes it will pass an and convert an HDMI digital signal as long as there is not HDCP encryption on the source signal.
| Posted: Thu Jan 12, 2012 9:39 pm Post subject: |
if that's true Nashou, let's see how many get returned.
| Posted: Thu Jan 12, 2012 9:51 pm Post subject: |
Ah, so you spoke from experience, it won't work with HDCP?
