Runco DTV 1100/aka Barco 1209 RGB VGA Resolution problem
miro
Posted: Thu Jan 05, 2012 6:57 am    Post subject: Runco DTV 1100/aka Barco 1209 RGB VGA Resolution problem
I recently entered the CRT Projector world, so excuse the newb questions!
Shocked
I have the Runco DTV 1100, and I have successfully done:
480p (BNC adapters for RGB)
1080p Analog via Xbox 360 (BNC adapters for RGB) -- this is through input '6'
1600*1200 VGA 75hz (and various smaller resolutions, 4:3...) -- this is through input '5'
Note: I am going VGA -> RGBHV (BNC).
However, I cannot for the life of me, get 1080p from my PC to the projector. I am using a laptop with a 7900 card, and a built in screen capable of 1920*1200 (tried simply cloning views and going to 1080p). My Nvidia drivers only detect the display as 1600*1200, and only give me options up to that. I get "Source not supported." once I force the 1080p resolution through Powerstrip (commonly advised). I have tried changing the signal, ie 50hz rather than 60hz.
I find it strange that the 1080p on the Xbox works without a hitch, but it is not so with the VGA input. As far as I know, this monster projector is capable of 2500*2000.
Any ideas on things to try? The only thing I haven't tried is the 'Port 3' (9 pin barco specific).
However, as quoted by Curt:
Caveat: Some port 3 boards seem unable to support 1080p. We are trying to determine which projectors are affected or if there's any pattern to this.
Unrelated to the question, how bad is this wear & tear on the tubes & life left? (Green & Blue).
ElTopo
Posted: Thu Jan 05, 2012 7:05 am    Post subject:
The wear looks not that bad still usable for hours and hours i think.
If you stay within the mask you should not have problems.
Barco Cine 9 the one and only
miro
Posted: Thu Jan 05, 2012 7:09 am    Post subject:
Currently I am outside of the mask. Every blue sky I can see the inner burn; it's not terrible, but it's there. Just move it back a bit further back to zoom into the mask I take it?
Ile
Posted: Thu Jan 05, 2012 10:36 am    Post subject: Re: Runco DTV 1100/aka Barco 1209 RGB VGA Resolution problem
Port3 wouldn't look that great with 1080p, circuitry is old design and bandwidth is somewhat limited. High resolutions will look much softer than port5 and picture have ugly "ringing" caused by too much peaking.
You should get port5 to accept 1080p 50/60Hz from pc. (75Hz would be over Datas 75kHz) First try to set both syncs to negative from Powerstrip, that should help. Also check from video card drivers that both syncs are enabled.
Then you can tweak other 1080p timings from Powerstrip. These porches should work also for 1080p.
http://www.curtpalme.com/forum/files/1080i96_623.png
That much wear must ruin picture uniformity. I couldn't stand uneven uniformity caused by much lighter burn in my projector and chanced tubes.
That kind wear is nasty, because you see all the time how much brighter that virgin phosphorus at sides are. If it's not bothering you, those should be fine long time.
I can't understand previous installation, why someone would buy 9" projector and use only 50% of tubes. Thumbs Down
HaydnG90
Posted: Thu Jan 05, 2012 2:09 pm    Post subject:
I replaced a green tube on my G90 with far less burn. For me it was unacceptable.
Posted: Thu Jan 05, 2012 2:52 pm    Post subject:
Someone did a terrible job installing that projector, it was about a foot or so too far back, the wear area is very small.
BTW, that's a 1209s you have there, a good step up from a plain 1209.
I'd replace the green tube, the blue is good for quite a bit more time, but the green burn is annoying.
Also, this is a Data 1209s, max scan rate of 75Khz. It should do 1080p from any source, but you need negative sync. Postive sync will result in no picture. Check to see if you have a sync inversion button within the video driver, or you might need to get an Extron 202 box to force negative sync output regardless of input sync.
Decibel
Posted: Thu Jan 05, 2012 4:18 pm    Post subject:
It's possible to upgrade?
Runco DTV1200 have scan rate limitation?
Domenico (Barco fan!)
Posted: Thu Jan 05, 2012 4:23 pm    Post subject:
No the DTV 1200 will scan to 135 (I think) Khz. It's very difficult to mod a Data, as you'd need to change 3-4 boards and it's not worth it. Still, a Data 1209/1209s will do 1080p no problem, counter to the advice I got from a couple of other CRT techs a few years ago.
miro
Posted: Thu Jan 05, 2012 5:11 pm    Post subject: Re: Runco DTV 1100/aka Barco 1209 RGB VGA Resolution problem
Thanks, I will give these settings a try.
Yeah, the history with this projector is that it was indeed a one-owner. The guy bought it new, locally from a high end store and the son ended up with it sitting in his garage years and years later (whom I bought it from).
I believe I currently have it at a proper length and that's why I'm seeing some of the wear zones. Unless I can score a green for an amazing price, I'll just make the best of it. I do notice with a certain amount of wear you have to tweak gain/color balance to make it a proper picture, however.
I'd like to add, the projector had 14.5k hours on it--I believe the tubes had been replaced in it's lifetime.
Posted: Thu Jan 05, 2012 5:12 pm    Post subject:
You should be able to tell by the date code stickers on the tubes, if they have them.
miro
Posted: Thu Jan 05, 2012 5:18 pm    Post subject:
Good to know! All of your info got me into the ballpark before getting a CRT. I guess I won't be doing 3D =).
I did have a setup question, however. My Red/Green are tack sharp, but I cannot get my blue as tack-sharp. There seems to be a little bit of haloing around it. All converged, they look fine. But try as I might, manual focusing just won't get me there, and the electronic focusing doesn't seem to either. I had done the schmeiplfug(sp) and the other manual adjustments for convergence/focusing. Perhaps I need to redo this one ? or is there another area I'm missing?
Thanks.
HaydnG90
Posted: Thu Jan 05, 2012 9:24 pm    Post subject:
Blue is always a little softer.
Posted: Thu Jan 05, 2012 11:37 pm    Post subject:
When setting the focus and astig in the menus, run the contrast at 100%. That pushes the tubes harder, and when you set the projector back to a normal contrast level, it will be super sharp. Also Haydn is right, the blue focus is always softer than the R and G. Since this is your first outing into CRT, do the full setup about 3 times so you get used to it, and do it over a 2 week period.
secstate
Posted: Fri Jan 06, 2012 3:08 am    Post subject:
I'd replace that green. My Runco 1100 had a green that was a bit better and I couldn't stand it. Also my Runco 1100 does 1080p from my HTPC just fine. I don't recall forcing negative sync but it might have defaulted to that and I use port 5.
Out of curiosity did that Runco per chance come from the DC area? Both of mine came from there with about 14,500 hours on the clock from a guy in DC who said he had pulled them and some others out of the Marriot boardroom and each of the techs got to keep some. So I know there are a few others out there someplace. They had supposedly been in standby most of the time and that makes sense because the tubes were original to the chassis and had not been replaced when I got the projectors.
Posted: Fri Jan 06, 2012 2:09 pm    Post subject:
Kudos to the sales guy that sold those originally if that's true, as the Barcos would have been $10K cheaper each...
secstate
Posted: Sat Jan 07, 2012 4:07 pm    Post subject:
LOL very true. From what the guy told me his company had also installed them. Supposedly the were installed at Marriott for only about two years. They were installed in a rear projection (nearly straight on the screen) mode and were left on 24x7 so there would be no warmup time (hence the hour count).
