Calibration Disk
nkourouk
Posted: Tue Dec 20, 2011 10:54 am    Post subject: Calibration Disk
Hello to everybody. I'm just starting in this forum. I would like to thank Kal for his very detailed guide for calibrating home theater TVs and projectors. I have the following question: I have the DVE pal version and regarding its use for the calibration procedure its not easy to use and several images are missing. I've seen in this post http://www.curtpalme.com/ChromaPure_EyeOneDisplay3.shtm
that there is a free calibration DVD from Chromapure to be used with their calibration software. I have downladed it and seems to have everything needed for the dumies guide. Is it ok to use it? Also is it NTSC or PAL coded?
Thank you
Posted: Tue Dec 20, 2011 2:29 pm    Post subject:
If it has all the patterns you need then you can certainly use it. I've never tried it myself.
The AVS709 calibration disc is also very popular. See: http://www.avsforum.com/avs-vb/showthread.php?t=948496
nkourouk
Posted: Tue Dec 20, 2011 3:27 pm    Post subject:
ok Thanks
Posted: Tue Dec 20, 2011 4:58 pm    Post subject:
Ahh Another Greek memebr! Gia Sou !! Very Happy
nkourouk
Posted: Tue Dec 20, 2011 5:33 pm    Post subject:
Geia sou kai esena Smile Thanash!
Posted: Wed Dec 19, 2012 8:24 pm    Post subject:
I'm looking for some kind of calibration disc where you can get some sort of film related material to surround the test image..
I imagine a 15x15cm window for the colors and gray scale, and some kind of noise whit a mix of colors and saturation that could be like average film material.
I would like to test how much the calibration changes from the normal test images to displaying the film. And stress the players when calibrating, to see if there might be a difference in performance, thats not there when using the normal calibration windows.
ConnecTED
Posted: Wed Jun 04, 2014 6:01 pm    Post subject:
3rd one here Smile
Ted's LightSpace CMS Calibration Disk
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1Display PRO, Chroma 5 PRO
Posted: Wed Jun 04, 2014 6:54 pm    Post subject:
3rd one here Smile
Thumbs Up
