MagnetBox 52" Rear Projection CRT TV - Power but no ima
Jeremy112
Posted: Fri Dec 09, 2011 8:36 pm    Post subject: MagnetBox 52" Rear Projection CRT TV - Power but no ima
Like the title says, its a Magnetbox 52" CRT made in February 1995, pretty old, but I do have a buyer for it once I get it fixed.
It powers on, I can hear the HV noise, and there is sound from the speakers, but no image, would this be a Regulator?
Model is an FP5230 if it helps Smile
Posted: Fri Dec 09, 2011 8:38 pm    Post subject: Re: MagnetBox 52" Rear Projection CRT TV - Power but no
Jeremy112 wrote:
Like the title says, its a Magnavox 52" CRT made in February 1995, pretty old, but I do have a buyer for it once I get it fixed.
Umm the title says MagnetBox . Wink
lol
Jeremy112
Posted: Fri Dec 09, 2011 9:14 pm    Post subject:
MagnetBox, Magnavox, only difference is MagnetBox was used in "The Simpsons" Smile
Posted: Fri Dec 09, 2011 11:50 pm    Post subject:
Can you test components?
Jeremy112
Posted: Fri Dec 09, 2011 11:55 pm    Post subject:
I do have the knowledge to test out the components yes, I'll admit I'm not sure exactly where the issue is, but I believe it to be on the Power Supply board.
This TV has the same exact issue an old Sony 27" CRT we had years ago had, every 4 or 5 years the Voltage Regulator would go out on it and cause loss of picture, but sound was still heard. That is one of the reasons I thought it to be a voltage regulator issue..
Posted: Fri Dec 09, 2011 11:58 pm    Post subject:
Test R934.
Jeremy112
Posted: Sat Dec 10, 2011 6:12 pm    Post subject:
macgyver655 wrote:
Test R934.
Mac, I checked the TV out this morning, before I read your post, I noticed a resistor blown out and burnt, and guess what, your spot on, its R934, when I replace it, is there anything else I should check? Does that resistore fail commonly on this TV?
Posted: Sat Dec 10, 2011 6:14 pm    Post subject:
Jeremy112 wrote:
macgyver655 wrote:
Test R934.
I'll PM you more info.
Jeremy112
Posted: Sat Dec 10, 2011 6:15 pm    Post subject: Re: MagnetBox 52" Rear Projection CRT TV - Power but no
lol
I have corrected it Razz
Jeremy112
Posted: Sat Dec 10, 2011 6:16 pm    Post subject:
macgyver655 wrote:
Jeremy112 wrote:
macgyver655 wrote:
Test R934.
Wow you don't waste time at all, I like it! Thanks Mac Smile
