Jeremy112
| Posted: Wed Dec 07, 2011 4:00 pm Post subject: NEC 9PG XTRA - Weird Horizontal Deflection issue... |
Last night I turned my 9PG Xtra on to go ahead and watch some TV, about 5 minutes after powering on I noticed that the horizontal deflection started having some issues.
All 3 colors were moving left to right. They were not freaking out all over the place like I've heard some peoples projectors do, and after a few minutes it warmed up enough to normalize back to where it should be.
My question is, is this the famed Toshiba transistor on the horizontal deflection board of all NEC PG projectors? This projector is in mint condition physically and aesthetically, but I know as parts get older they break down.
If it is the transistor I have a couple brand new Toshibas here so I could throw one in, I just wanted some expert opinions before I started.
| Posted: Wed Dec 07, 2011 4:10 pm Post subject: |
Nope, transistors either work or don't work, not somewhere inbetween. Clean the H yoke connectors on the deflection board with Caig contact cleaner. That should do it.
Jeremy112
| Posted: Wed Dec 07, 2011 4:16 pm Post subject: |
Thanks curt, that would be great if thats all it is, I will check that out right now, thank you!
Jeremy112
| Posted: Wed Dec 07, 2011 4:39 pm Post subject: |
Curt, that eliminated the problem, thank you very much!! It was the first issue that had occured since I got it, so I am glad it wasn't a problem part
Thanks a million!
| Posted: Wed Dec 07, 2011 4:44 pm Post subject: |
Mine does this when the weather is humid. Not nearly as bad as it used to though.
I noticed today when i turned it on it was going quite blue, thought i was losing the red but it seems more like the red was just dimming down abit.... I think the Gain CTRL board may have had the dick in mine...
Also got some issues where a small bright object will cause a darkened line across the screen in line with it.... That has only started today also...
Lots of fog here past could of days...
| Posted: Wed Dec 07, 2011 4:47 pm Post subject: |
| CasetheCorvetteman wrote: | . I think the Gain CTRL board may have had the dick in mine...
I'm sure this is a legit Aussie saying, but it suuuure reads differently in North America. That was my LOL of the day.
Jeremy112
| Posted: Wed Dec 07, 2011 5:12 pm Post subject: |
| Curt Palme wrote: | | CasetheCorvetteman wrote: | . I think the Gain CTRL board may have had the dick in mine...
I'm sure this is a legit Aussie saying, but it suuuure reads differently in North America. That was my LOL of the day.  |
Jeremy112
| Posted: Wed Dec 07, 2011 5:14 pm Post subject: |
I have to say the 9PG Xtra is a fine machine, I only wish my XG was as silent as the Xtra.
I dont suppose any of you would know of a good replacement for the XG fan? Otherwise I think I saw a mod topic for it on here somewhere...
| Posted: Wed Dec 07, 2011 6:09 pm Post subject: |
HAHA!! Glad you liked it!
| Posted: Wed Dec 07, 2011 8:40 pm Post subject: |
| Jeremy112 wrote: | I have to say the 9PG Xtra is a fine machine, I only wish my XG was as silent as the Xtra.
I dont suppose any of you would know of a good replacement for the XG fan? Otherwise I think I saw a mod topic for it on here somewhere... |
Be glad to live in the US... the 220-240V version PG xtra has two more fans in the power supply. As much as I can recall I found the XG as loud as my PG xtra...
| Posted: Wed Dec 07, 2011 11:58 pm Post subject: |
I'm sure you all know by now that is Curt's HV probe
Is that a HV probe in your pocket or are you just happy to see me
_________________ Chip
Jeremy112
| Posted: Thu Dec 08, 2011 4:28 pm Post subject: |
Lmao Chip.
Gjaky, Would that mean that my fan on my deflection board for the XG1100 could be going bad???? Its the loudest fan in the XG, if unhooked the XG sounds as loud as the PG Xtra, but otherwise it sounds like a dying giraff
I bought a fan for it a while back, and although it was the right dimensions and electronic specifications it wouldn't work, so I tested it outside of the XG and it did work...
I just dont want to buy another replacement that doesn't work with the XG
| Posted: Thu Dec 08, 2011 4:45 pm Post subject: |
| Jeremy112 wrote: |
I just dont want to buy another replacement that doesn't work with the XG  |
Well, I have that two extra fans, I don't know if the European XG differs from the US type.
I don't know the fan wiring in the XG but I know that the PG xtra fan pinout differs from the PC type fans, if you are interested I can tell you how to rewire.
| Posted: Thu Dec 08, 2011 5:53 pm Post subject: |
| Jeremy112 wrote: | | I have to say the 9PG Xtra is a fine machine, I only wish my XG was as silent as the Xtra.. | you guys thing the PGX is quiet I turned that thing on last night and was looking for the built-in hose to vacuum my shop floor with
| Posted: Thu Dec 08, 2011 5:55 pm Post subject: |
You need a Sony 1292
Jeremy112
| Posted: Fri Dec 09, 2011 9:07 pm Post subject: |
| draganm wrote: | | Jeremy112 wrote: | | I have to say the 9PG Xtra is a fine machine, I only wish my XG was as silent as the Xtra.. | you guys thing the PGX is quiet I turned that thing on last night and was looking for the built-in hose to vacuum my shop floor with  |
lmao! thats too funny, maybe your PGX has bad fans? my PGX has around 400 hours on the tubes and chassis, nothing like hearing new fans
| Posted: Fri Dec 09, 2011 9:12 pm Post subject: |
Your listening to close. That's your ear flapping as the blades hit it......
| Posted: Mon Dec 26, 2011 4:15 am Post subject: |
| macgyver655 wrote: | | draganm wrote: | | Jeremy112 wrote: | | I have to say the 9PG Xtra is a fine machine, I only wish my XG was as silent as the Xtra.. | you guys thing the PGX is quiet I turned that thing on last night and was looking for the built-in hose to vacuum my shop floor with  |
Your listening to close. That's your ear flapping as the blades hit it......  | LOL, I'm used to the marquee's and they are simply quieter, after the fan modification they're a lot quieter.
Jeremy112
| Posted: Mon Dec 26, 2011 5:08 pm Post subject: |
I guess to me its quieter because in the back of the basement where my rack is, I have 2 24 port 3Com network switches and an HP Proliant server running so the projectors are pretty hard to hear in the first place, but the PG Xtra is much quieter than the XG in any case, as for a Marquee I've never gotten the honor to see one in person so I cannot say
| Posted: Mon Dec 26, 2011 9:56 pm Post subject: |
| Jeremy112 wrote: | as for a Marquee I've never gotten the honor to see one in person so I cannot say  | well "honor" might be an exaggeration, at least AFA an old stock surplus 8500 is concerned.
After looking at this 9PGX with just an amateur set-up it actually looks really good. I would run it in my HT if need be. The P16 tubes and stock HD-145 lenses give it an edge over the typical high hour marquee or Barco with 180 tubes and HD8 lenses.
You really need a pristine low hour or modified marquee 8 inch with Moome card to beat it .Did I just say that
