xg110 ceiling mount angle
edavi394
Posted: Mon Dec 05, 2011 3:10 pm    Post subject: xg110 ceiling mount angle
Hi, in the xg installation manual it says the angle of the projector should be either 12.4 ° or zero for my screen size. how critical is it to be in that range? I am trying to adjust the focus rings. I have to check my angle it is neither of those I am sure. It will be closer to zero since I wanted to raise the bottom of the screen out of my 1 year old's reach. I would guess it is mounted at about a 5° angle. Is there a way to set the focus rings for something other then what is called out or am I out of luck?
Posted: Mon Dec 05, 2011 4:08 pm    Post subject:
What is your screen size?
edavi394
Posted: Mon Dec 05, 2011 4:21 pm    Post subject:
100" wide 2.35:1 i think I have to check again i just masked around it yesterday
Posted: Mon Dec 05, 2011 4:27 pm    Post subject:
Ok, here's the first problem. That chart is for the diagonal measurement of a 4X3 screen. So you would need to recalculate your screen width to that diagonal. Next, since you wont really be using the upper and lower portions of the tube face the adjustment rings are not as critical, maybe only for fine tuning the L and R center edge.
edavi394
Posted: Mon Dec 05, 2011 5:28 pm    Post subject:
Ok thanks for the info that should help.
edavi394
Posted: Mon Dec 05, 2011 6:48 pm    Post subject:
well it looks like the screen is 98" wide at 2.35:1 and the rear of the projector is slopping down and about 5° angle so that puts the front at what around 7°? what is the best position then for the focus rings i know macgyver655 said it is not as important since i wont be using the hole raster but what should the Poisson be for this angle and size? thanks
Posted: Mon Dec 05, 2011 7:00 pm    Post subject:
My conclusion comes to: 321232 Mr. Green
edavi394
Posted: Mon Dec 05, 2011 7:39 pm    Post subject:
Awesome thanks I will give that a shot
