nut sizes from a marquee lc?
dvh99
Posted: Wed Nov 16, 2011 1:47 am    Post subject: nut sizes from a marquee lc?
this has been asked before of course but what are the nut sizes that hold the bellow in place and what is the size of the top 2 nuts?
9" marquee housings.
Posted: Wed Nov 16, 2011 3:25 am    Post subject:
they are called bolts. Wink
You and I are the marquee nuts!! Very Happy
dvh99
Posted: Wed Nov 16, 2011 3:58 am    Post subject:
haha, i always confuse those nuts and bolts.
now i will never forget.
still want to know the sizes btw, got myself a "new" pt22 green from nidi.
Posted: Wed Nov 16, 2011 3:50 pm    Post subject:
Hello
The larger allen bolts are all 1/4-20, 1/4" bolt diameter with 20 threads per inch.
Posted: Wed Nov 16, 2011 9:16 pm    Post subject: Re: nut sizes from a marquee lc?
actually the correct term is socket cap screws Wink
For the bellows they are 6-32 socket cap screws 3/8" long.
For the Glycol fill screws they are also 6-32 x 3/8" but stainless steel button head
Posted: Wed Nov 16, 2011 9:22 pm    Post subject:
If you check around here, not only are there lots of Marquee nuts, they're also really big! Razz
dvh99
Posted: Thu Nov 17, 2011 5:45 am    Post subject: Re: nut sizes from a marquee lc?
you mean 6/32 inch diameter?
that means they are almost 1/2cm that can`t be right.
Posted: Thu Nov 17, 2011 5:57 am    Post subject:
big ones are easier to see with my old worn out eye-balls
Mr. Green
dvh99 wrote:
you mean 6/32 inch diameter?that means they are almost 1/2cm that can`t be right.
LOL that's funny Laughing
not sure if your joking but I can't blame you for being confused by English bolts. It's a number #6 screw (.136" diameter) w/ 32 threads per inch = 6-32 Thumbs Up I have bought and installed a few hundred so I'm pretty sure that's the right size.
Don't ask me where the number system came from, they go 00-80, 2-56,3-48,4-40,6-32,8-32, 10-24,10-32, and there was even a 12 and 14 at one time which are extinct now like the dinosaurs. Mr. Green
dvh99
Posted: Thu Nov 17, 2011 9:18 am    Post subject:
i wasn`t joking.
those screws are very hard to find, only ones i could find here are steel bolts.
ok looked 2 minutes and found these,
http://www.fastener-express.com/6-32-x-38-socket-head-cap-screw-stainless-steel-qty-100.aspx
is that the correct one, don`t know what the 18-8 stands for.
barclay66
Posted: Thu Nov 17, 2011 11:16 am    Post subject:
Umm, not really.
You may look for article number 360364381032 in German eBay...
The seller has almost every type of bolts/screws/nuts etc. Look for the term "UNC".
Regards,
barclay66
Posted: Thu Nov 17, 2011 5:53 pm    Post subject:
yup, those are correct. 18-8 is the code for the metal, AKA 304 corrosion resistant stainless steel. High Chromium content makes it non corrosive and non-magnetic.
dvh99
Posted: Fri Nov 18, 2011 2:33 am    Post subject:
thanks for confirming.
ordered 200 pieces.
7 usd for 100 screws is cheap, it`s a shame the stainless steel wasn`t used in the first place.
