A problem with my scaler?
Z-rizz
Posted: Wed Nov 02, 2011 7:54 pm    Post subject: A problem with my scaler?
Hi to you all!
Recently, I hooked up my LD player, a LD-S9, to my BARCO using a FAROUDJA DVP5000. I read and heard that this should be a great combo. Still, I noticed two things: First, I cannot get read of horizontal colored bars (redish). I though the RGB cable was the culprit and changed it for a VideoQuest. Almost no effect. Does it come from the scaler? Second, when I set the resolution to 1080i, which should work fine on my 808s, I get annoying distortion at the top of the picture. If I choose a lower def, the distortion disappears. If a go up to 1080p, the picture goes dark. Again, is my scaler defective? It is now a bit old. Is there a better choice than the DVP5000?
Thank you in advance for any insight.
Steven
Rizz
