dochlywd
Joined: 25 Apr 2006 Posts: 346 Location: Saint Louis, Missouri
| Posted: Mon Oct 31, 2011 12:36 am Post subject: SONY G70 ERROR 26!!!! |
Can anyone give us a clue as to what would be throwing this error. It suggests that there is a lens removed but they are all secure along with having the grounding wire attached.
I was trying to help my buddy over the phone but ran out of options.
Thanks!
Doc
| Posted: Mon Oct 31, 2011 12:52 am Post subject: |
Check that the connector's other end is plugged into the PA board properly. Make sure there;s a screw through each of the grounding lugs on the lens. If the screw is missing, chances are there's no connection to ground out each of those lens wires.
Otherwise there's probably some rare fault on the PA board causing a false 25 error.
dochlywd
| Posted: Mon Oct 31, 2011 12:56 am Post subject: |
Thanks Curt!!
I'll try to swing by there tomorrow and have a look at things. This guy is pretty sharp with when it comes to audio, but his brain falls out of his ass when it comes to projectors!!!
Doc
| Posted: Mon Oct 31, 2011 1:11 am Post subject: |
Geez Doc, another lens error...... Did you learn from the last one?
dochlywd
| Posted: Mon Oct 31, 2011 12:28 pm Post subject: |
I know! However, this one worked fine before it was moved and sat in his basement for 2 to 3 years. I would think it's something simple.
And yes, I did learn from the last one. When it comes to tracing faults down, I need to stay as far away as possible and send the appropriate boards out to the experts!!!!!!!!!!!
Doc
dochlywd
| Posted: Tue Nov 01, 2011 3:54 am Post subject: |
Was able to get by there this afternoon and reseat the lens grounds, their connections to the PA board and the PA board itself.
All is fine again!!!
Thanks!
Doc
| Posted: Tue Nov 01, 2011 8:04 pm Post subject: |
Doc the new Ken Whitcomb
