Memory Loss on Sony
retro-rick
Posted: Sun Oct 23, 2011 11:27 pm    Post subject: Memory Loss on Sony
just when I had the damn thing dialed in. My 1270 has somehow lost all the memory settings. I can redo the setup, that is fine with me. I need to know what could cause this. A little back story on this is that sometimes it seemed not to want to sync to the programed memory. I would turn off the projector and power it back on and all would be right in the world.
As far as I understand there is no battery so that cant be it. Oddly enough when I powered down the PS3 the 1270 powered down with it. It would do that randomly with the PS3 and the Xbox.
arggh!!!
it is a good thing I enjoy doing this set up crap... or at least used to.
retro-rick
Posted: Mon Oct 24, 2011 2:03 am    Post subject:
Im back in the saddle let see if this is an anomoly, or something more insideous.
Posted: Mon Oct 24, 2011 4:28 am    Post subject:
Are both the projector and the PS3 plugged into the same outlet?
retro-rick
Posted: Mon Oct 24, 2011 5:40 am    Post subject:
Jeez analog, do you let anyone else answer? To answer your question• same outlet,no. Same circuit yes. Would you believe that my old pioneer prologic receiver is part of the chain. I may have to get creative. Thanks.
Posted: Mon Oct 24, 2011 6:30 am    Post subject:
Anyone's welcome to answer. I just got here first. Very Happy
Are you sure the 1270 doesn't have a battery?
and yes I would believe your ProLogic is part of the circuit. Use whatever is handy.
rosenbush
Posted: Thu Oct 27, 2011 2:16 pm    Post subject:
When you said, "Re- do the set up because lost of memory settings" . Do you mean The values changed? or with the same values (that work before) you need to re-set up again?. As far I know there is no battery for the memory, it should keep the values when you save them.
