Is Marquee/ dvdo edge/ oppo 95 possible for 3d
richmond5
Posted: Fri Oct 14, 2011 4:26 pm    Post subject: Is Marquee/ dvdo edge/ oppo 95 possible for 3d
Hi:
I have Marquee 8500 hookup with DVDO edge and Moome ext HDMI 1.4. Playing with OPPO 95, can not get any image at all. Is the setup possible for 3d?
Sparky015
Posted: Fri Oct 14, 2011 11:28 pm    Post subject:
you need the box for decoding the 3D and the glasses. I don't know what the specs are on the DVDO, but can it process 3D? Either way, you need the interface with the glasses.
~Paul
cinema mad
Posted: Sat Oct 15, 2011 3:24 pm    Post subject:
As far as external video processors & 3D on CRT go The Edge can only pass 3D like the Duo, How ever The Lumagen Radiance series VPs handle all current Consumer 3D formats inc Custom timings for CRT projectors.. But for Active 3D you also need the lumagen (HDMI) CRT 3D sync box... For Dual projector Passive 3D 2 Lumagen radiances are required...
So the main reason your not getting 3D is because
1. There is no way to sync the Active Glasses..
2. Because the Oppo like all blu-players rely on EDID for 3D mode/Display compatibility, the Moome ext box may not report 3D
which the Radiance EDID has the ability to Report 3D compatible to 3D Blu-Players..
