ekwoodard
| Posted: Wed Aug 24, 2011 4:26 pm Post subject: NEC pg6000 not working after moving. |
I came across two PG6's they were moved from one location where they were working great to a new location where they have a green tint. Looking into the tubes the red and blue seem to be defocused. Both units have the same problem after being moved where they did not before hand. What am I missing?
_________________ If there is no point to the ball;
there is no point to the game.
| Posted: Wed Aug 24, 2011 4:29 pm Post subject: |
Post some pix of the images you're seeing.
Are you using the same source equipment? Have you done a new signal entry? Have you checked the AKB setting? Have you refocused the lenses and done a full setup?
ekwoodard
| Posted: Wed Aug 24, 2011 5:26 pm Post subject: |
Originally nothing had changed with the setup other than location. He did the basic setup. I am in the process of repairing the remote so that a complete setup can be done. Does it sound like something that should be resolved with a complete setup?
rosenbush
Joined: 14 May 2010 Posts: 94 Location: Brownsville Texas
| Posted: Fri Aug 26, 2011 2:59 am Post subject: |
Did you match the same distance to the screen on both sites?
Just asking.
ekwoodard
| Posted: Fri Aug 26, 2011 5:10 am Post subject: |
No the new room was not as long as the old room. If the tubes are adjusted would it still make a difference?
rosenbush
| Posted: Sat Aug 27, 2011 4:03 am Post subject: |
Several factors may have changed
you'll need to re-focus all over again, not just the lenses
