Samsung HLP5663WX XAA 56" DLP
romero.video
Posted: Thu Aug 11, 2011 4:44 am    Post subject: Samsung HLP5663WX XAA 56" DLP
Does not turn on. When plugged in, you hear a click like it's trying to come on. Indicator on the power button shows "lamp". If left plugged in, it will cycle from lamp and go to standby and timer, then back to lamp. It keeps doing this. I read in another place where if it's not the lamp, it's either the ballast or the DMD board. I'm thinking it's the board. Any other ideas? I have another dlp set i'll be posting about once i get the model number.
TheVerge
Posted: Thu Aug 11, 2011 8:21 pm    Post subject:
Hello other Arkansas person. If you have put a new lamp in it, it is probably the ballast.
romero.video
Posted: Thu Aug 11, 2011 10:43 pm    Post subject:
Oh, where you from. I'll check into the ballast as well. Any way i can tell for sure it's that?
Posted: Fri Aug 12, 2011 1:38 pm    Post subject:
I read this post and just moved on because based on your other posts I can't tell if your looking for help to repair some of your stuff or just looking for quick fixes. If your not at least slightly involved in electronics repair, even as a hobbyist, then you really shouldn't be poking around in high voltage areas. Bad things can happen.
TheVerge
Posted: Fri Aug 12, 2011 1:56 pm    Post subject:
Fayetteville, i would bet it's the ballast. It's beyond my skill to know how to test this for sure, other than try to get a new on from samsung or ebay and try it out.
3 things break often in dlps. Bulb, Ballast, and Color Wheel. It isn't the color wheel, and i'm assuming you put a new bulb in it... process of elimination. Seems like those 3 things are like, 99% of the problems.
Posted: Fri Aug 12, 2011 2:01 pm    Post subject:
What in his post makes you assume it's not the color wheel?
romero.video
Posted: Fri Aug 12, 2011 4:30 pm    Post subject:
It's more of a hobby and it has been since the early nineties. I'm just looking for some direction as i really want to repair what i have. i know all about the risk and have worked on well over 100 different sets but i don't consider myself an expert and always run into something new. i hope someone can help me.
TheVerge
Posted: Fri Aug 12, 2011 7:20 pm    Post subject:
Sounded like maybe the lamp was trying to strike.
Posted: Fri Aug 12, 2011 10:12 pm    Post subject:
When you first turn it on check to see if the fan is spinning. Then listen to hear if the color wheel spins up.
romero.video
Posted: Sat Aug 13, 2011 1:09 am    Post subject:
i did notice something like a spin-up. you could hear it after the click
Posted: Mon Aug 29, 2011 12:50 am    Post subject:
Hmmm, this guy hasn't been around since the 14th. Wonder if he was poking around that ballast with the set plugged in.... Shocked
romero.video
Posted: Sun Sep 04, 2011 12:01 am    Post subject:
LOL, no I'm still here. Actually just now getting around to working on it. I have a new lamp module on the way as well as a remote fore it. Will update once i get that put in.
