10PG shut down error code blinking "E0" - solved
hansilili
Posted: Sat Aug 06, 2011 11:23 am    Post subject: 10PG shut down error code blinking "E0" - solved
The title says it all. Minty looking unit strarts and shuts down after a couple of minutes with a blinking 03 in the display. I have a working unit here too so I could start swapping boards to identify the error. Any suggestions on how to proceed?
Hans
Posted: Sat Aug 06, 2011 1:07 pm    Post subject:
Are you sure you are reading that code correctly. You might be reading it upside down and mistaking the 3 for a F.
FO is a fan stoppage. Make sure all the fans are spinning on power up.
hansilili
Posted: Sat Aug 06, 2011 2:16 pm    Post subject:
Thanks Stephuel,
I found out myself that this should read E0 insteaf of 03. Not F0 though.
But indeed, the fan on the bottom between F- and C-board is not turning. I was about to change that for a quieter one anyway and hope the error will then be solved.
Case closed
Hans
Posted: Sat Aug 06, 2011 3:58 pm    Post subject:
Old MacDonald had an NEC
E O E O I.....Smile
hansilili
Posted: Sat Aug 06, 2011 4:35 pm    Post subject:
the sucker is out, but I had to move the green and red CRT to access it. The 10pg C-board cooling is what they should have built into the smaller units as well. There is a nasty to remove plastic windshield directing the air towards a big heat sink under the f- and c-board. The smaller PGs have those mounted directly on the bottom plate. That's why i glued on an extra heat sink from the outside.
Posted: Sun Aug 07, 2011 12:21 pm    Post subject:
Is E0 the 10 PG's version of a fan stopped error code? My PG plus service manual lists F0 as that error code and has no listing for E0 that I could see. I didn't spend to much time looking though.
hansilili
Posted: Sun Aug 07, 2011 3:32 pm    Post subject:
It was definitely a blinking E0 and not F0. I also do not have a Manual with this code but will try to reproduce it when I change out the other fans (ordered on Ebay yesterday).
