VP-50. Is is usable with out the remote?
Posted: Tue Aug 02, 2011 12:40 am    Post subject: VP-50. Is is usable with out the remote?
IS the VP -50 usable without the factory remote? Or is it a door stop?
wallace123456
Posted: Thu Sep 08, 2011 4:54 pm    Post subject:
As far as I know, everything on the remote is available on the front panel and you can see where you arfe going via the small lcd display. I can do set-up and all other options front the front panel.
But, I just thought about the test patterns; not sure if they are there. I'll try to remember and check mine tonight.
wallace
wallace123456
Posted: Fri Sep 09, 2011 2:40 am    Post subject:
I cannot get the test patterns from the front panel. Otherwise, the front panel will get you all the set-up stuff. You can also use a universal programmed remote, or the serial input. If you want, I'll email all the owners manual stuff.
wallace
