gan
Joined: 10 Feb 2007 Posts: 36 Location: Geraldton Western Australia
| Posted: Thu Jul 28, 2011 3:54 am Post subject: BG 808s red leds |
Hi all,
Picture just dropped out on my 808s and after isolating every component in the chain, I dropped the hood on the PJ and found a red led on one of the boards ( unsure how to identify it ) and also on the aluminium drop down cover there are four leds lit with one of them flashing intermittently,the description alongside the flashing led is labelled Processor Cycles.Would this be the reason for the picture dropping out? and if so is it an easy fix?
UPDATE: okay removed the board with the lit led and the number on it is R7622686 and it has another smaller board attached with part number R762268S
| Posted: Thu Jul 28, 2011 4:02 am Post subject: Re: BG 808s red leds |
| gan wrote: | Hi all,
Picture just dropped out on my 808s and after isolating every component in the chain, I dropped the hood on the PJ and found a red led on one of the boards ( unsure how to identify it ) and also on the aluminium drop down cover there are four leds lit with one of them flashing intermittently,the description alongside the flashing led is labelled Processor Cycles.Would this be the reason for the picture dropping out? and if so is it an easy fix? |
The drop down cover with the flashing LED sounds like "CPU Cycles" and that should be flashing. The other RED LED if that is at the back of the projector on a board that appears to be on its own then that is the EHT board and a red LED is bad news.
| Posted: Thu Jul 28, 2011 4:15 am Post subject: |
No, those lights mean nothing. Check the tech section of the main site, it has all boards and board descriptions listed.
You need to check the lights on the G2 board and the ones on the EHT board. Post back what red lights are on.
THE red lights you're looking at on the controller board mean literally nothing in the case of a projector problem. If you can turn the set on and off, 90% of the controller board is working. Your problem is elsewhere.
gan
| Posted: Thu Jul 28, 2011 6:52 am Post subject: |
Thanks for the help
Found the particular information and the board is called Vertical board and if the red led is lit it could mean either a bad vertical board or theres no signal being fed to it.No other red leds lit inside the PJ,so going back to the start heres what ive done so far,first the signal chain
DVD,SET TOP BOX,VCR > DVDO VP 30 > HDMI > HD FURY2 > GAMMA X > PJ
Bypassed DVDO with both DVD and SET TOP BOX to wall socket... no signal
Bypassed HDMI cable by hooking up a dvd player i know is in working condition directly to HD FURY 2 with another HDMI cable.....No signal
This then leaves the HD FURY and its power supply the only two components left.It has the blue led lit but also emits a red light from the hole next to the HDMI input,havent noticed this before.Optical audio perhaps??
Possibly the power supply to the FURY could be the culprit,have a Moome EXT FULL HD V2 to swap the HD FURY out of the chain but keep getting a flashing red led on that when the power is connected to it and possibly because of that no signal is output....not sure why that is,its the power supply that was supplied with the V2 so should be in sync?
Now going to try composite cable directly from the DVD to the PJ to see if that will work.Shall keep you posted.......
barclay66
| Posted: Thu Jul 28, 2011 9:37 am Post subject: |
| gan wrote: | | It has the blue led lit but also emits a red light from the hole next to the HDMI input, havent noticed this before. Optical audio perhaps?? |
So you have a HDFury III. If the top blue light is constantly on the it means the HDFury is decoding a video signal from its HDMI inputs. The red light out of the nearby connector is in fact the optical output of digital audio being extracted from the HDMI signal. As you describe it, everything looks normal.
I don't think its a source issue here. The Barco should start up without any source connected and then should show a splash screen. If this is not the case, an internal failure most likely is preventing it from doing so.
Go with Curt's recommendations. He may have worked on zillons of those machines...
Regards,
barclay66
| Posted: Thu Jul 28, 2011 10:11 am Post subject: |
Its rooted mate. Send it over here to QLD, ill buy it off you and relieve you of your troubles. HAHAHA!!
Hope you get it fixed
| Posted: Thu Jul 28, 2011 12:53 pm Post subject: |
Even with no signal, do you get the onscreen menus or test patterns? Trying to figure out if it's a signal or projector issue.
gan
| Posted: Thu Jul 28, 2011 1:21 pm Post subject: |
Yes,get all internal patterns, convergence adjustments etc.
Have tried all ports so far but no picture.PJ fires up and runs no probs
The only red led i can see is on the vertical deflection board
| Posted: Thu Jul 28, 2011 1:46 pm Post subject: |
OK, I'm guessing this is a signal problem. Try the sync inversion switch on the GammaX, the BArco will not work with positive sync.
gan
| Posted: Thu Jul 28, 2011 2:18 pm Post subject: |
Ok tried that and no change except this time on start up the PJ displayed the barco identification screen which hasnt happened before.
Also during the times when the picture was dropping out there was a message Warning:source not available.
| Posted: Thu Jul 28, 2011 2:21 pm Post subject: |
So I'm guessing that the setup was working fine for a while? If so, switch the GammaX back to where it was, since it was working before.
At this point I'd feed an RGBHV signal from a computer into the Barco, making sure you have positive sync. Your V board could be bad, but the RGB switcher board also could be bad. You have pressed '5' on the keypad, selecting the port 5 BNC inputs, right? If the set got switched to another input accidentally, you could lose the image.
gan
| Posted: Thu Jul 28, 2011 2:33 pm Post subject: |
Yes the setup was working fine until suddenly the picture started to dropout intermitently then no picture at all.
And yes the relevant number for each port is pressed but no change.
Will feed a RGBHV signal to it and keep you posted as to the outcome
Cheers!
gan
| Posted: Thu Jul 28, 2011 2:45 pm Post subject: |
On startup there are no red leds lit until 5 is pressed on the keypad then the one on the vertical board lights up and stays constant.
| Posted: Thu Jul 28, 2011 3:00 pm Post subject: |
I'm guessing RGB input board, or a source problem. Don't forget to try a new RGB cable. Loss of 1 sync cable, and you've got nuffin'.
gan
| Posted: Mon Aug 01, 2011 11:53 pm Post subject: |
Fed the Pj a RGBHV signal from the laptop via a new cable and no response,also used a HDMI cable
Also connected a DVD player i know is in working condition via Composite and S Video with no image
displayed.So have tried all ports so far except port 3 and all with no response from the PJ.
gan
| Posted: Tue Aug 02, 2011 4:25 am Post subject: |
Hey Curt,do you have an RGB switcher board?
Would like to buy one and swap it out with mine
even if this doesnt fix the problem then i will have
a spare.
Cheers!
