babyman1737
| Posted: Wed Jul 06, 2011 5:10 am Post subject: New to projectors, VP? |
Well I'm helping the family set up an older Runco 933, and it doesn't have the original VP with it anymore. The RGB cables lead to the media cabinet where they pigtail into a piece that looks about like a 15pin d-sub connection or such.
Now for the question: I'm fairly certain I need to purchase a VP to make the projector work (unless I use the 15pin input on the projector with a computer). It looks like some people use an HDfury2 unit? Maybe try to find original Runco 933 (old school) unit? A newer Runco unit? Lumagen is out of price point.
Needs: 720p to watch blu ray from PS3 (see sig). I would like to route PS3 through my AV receiver, then go component output to my projector. Which crazy little box should I buy? I'd really like to not spend TOO much. Less than $300 if possible.
| Posted: Wed Jul 06, 2011 5:30 am Post subject: |
Are you using HDMI or component?
Welcome to the forum.
babyman1737
| Posted: Wed Jul 06, 2011 5:54 am Post subject: |
| AnalogRocks wrote: | Are you using HDMI or component?
Welcome to the forum. |
Thank you. I plan on using HDMI v1.1 from the PS3 to Onkyo receiver so I can listen to DVD-A and DTS 5.1 movies. From the Onkyo to the projector I plan to use component cables, mostly so I can view the movies in 720p. I have no need to get audio to my projector (that I know of?).
So both. But for the projector end, it should be component only.
_________________ Runco 933, PS3, onkyo TXSR803, (5) klipsch kl650
| Posted: Wed Jul 06, 2011 3:07 pm Post subject: |
| babyman1737 wrote: | | AnalogRocks wrote: | Are you using HDMI or component?
So both. But for the projector end, it should be component only. |
this will work.
http://www.moomecard.com/
babyman1737
| Posted: Thu Jul 07, 2011 2:43 am Post subject: |
That moomecard looks pretty good. $280. Thanks for the great suggestion, that looks like my best option so far.
Any other suggestions? Again, HDMI isn't necessary (do most people run audio to their projector?), only component. Even a VP that could easily be found used for a cheap price too.
| Posted: Thu Jul 07, 2011 2:51 am Post subject: |
This won't work. You can't get HDMI in and analog out of a receiver.
You will need the Moome box Athan linked to.
babyman1737
| Posted: Fri Jul 08, 2011 4:14 am Post subject: |
You will need the Moome box Athan linked to. |
Wow, great point. I never knew a receiver couldn't switch from HDMI down to component.
Is HDfury 2 or 3 similar or a direct replacement for Moomebox? If so, pros/cons of each?
rtart
| Posted: Sun Jul 17, 2011 10:38 pm Post subject: |
Can't get DVD-A from your PS3 either. SACD is available on only the very early (4-USB port) fat PS3's.
