dvh99
| Posted: Mon Jun 13, 2011 2:24 pm Post subject: encapsulated battery on marquee clm. |
hi, when replacing the battery does it matter if the new battery is not encapsulated.
| Posted: Mon Jun 13, 2011 2:25 pm Post subject: |
No, but why not get the right one?
| Posted: Mon Jun 13, 2011 3:10 pm Post subject: |
| Curt Palme wrote: | | No, but why not get the right one? |
Hehe
Where is the challenge in that?
dvh99
| Posted: Mon Jun 13, 2011 3:39 pm Post subject: |
cannot find the same model curt.
| Posted: Mon Jun 13, 2011 3:48 pm Post subject: |
really? Let me do some checking...
I can get some within a week, by the time postage to me is added, you're looking at about $12 each.
| Posted: Mon Jun 13, 2011 4:02 pm Post subject: |
Hello
Renata type 175-0, I have three on hand, $36 and postage for three.
dvh99
| Posted: Mon Jun 13, 2011 4:21 pm Post subject: |
does that include the clm it sits on
dvh99
| Posted: Mon Jun 13, 2011 4:40 pm Post subject: |
it is a cr2032 cell inside the encapsulation, this is from the renata datasheet but even that cell without encapsulation isn`t available anymore.
this is a 235mah and the closest farnell supplies is 300 mah, so a bit more capacity and close to the same size.
| Posted: Mon Jun 13, 2011 4:43 pm Post subject: |
You seriously are arguing over the $12 cost of a battery? I knew we were all really cheap on this forum, but that takes the cake!
dvh99
| Posted: Mon Jun 13, 2011 4:49 pm Post subject: |
no no, this isn`t even for me.
if it were for me i would have said send it right away.
i cannot say ok gimme some without consulting my friend first.
it is just that i have to setup his pj and if it keeps loosing the settings every time its been switched off, it gets frustrating .
so i want this resolved quickly.
| Posted: Mon Jun 13, 2011 5:06 pm Post subject: |
I personally would not be comfortable with an exposed battery on a hard to find $2000 CLM, but that's just me...if it leaks, the board is shot.
| Posted: Mon Jun 13, 2011 5:51 pm Post subject: |
Guys
It is filling out customs forms, standing in line at the post office, at my price I still lose money cause it is time consuming for anything offshore..........
dvh99
| Posted: Mon Jun 13, 2011 11:24 pm Post subject: |
probably no battery issue.
edit: measured 3.025 volts.
i replaced the static ram u31 and 32 and all seems fine again, let`s see if it holds settings till tomorrow, i will report back tomorrow.
edit: 15-6-2011 . it`s still holding the settings, how did this ram could go bad?
dvh99
| Posted: Wed Jun 15, 2011 4:22 pm Post subject: |
http://www.farnell.com/datasheets/32799.pdf
these seem to have the same pinout as the ones used in the marquee.
mike or tse? any comments on why this would work or not work.
i have taken 2 known good chips and placed them on the clm that lost its settings.
as you can see in my post above that solved the problem.
but now i have a clm lying around with 2 missing sram chips.
