Runco 1101 gamma
newcrt07
Posted: Tue Jun 07, 2011 2:17 am    Post subject: Runco 1101 gamma
would it be better to adjust gamma on a runco 1101 through the maintenance controls or use a device such as hd fury 3 with gamma correction?
zGman
Posted: Tue Jun 07, 2011 3:13 am    Post subject:
Posted: Tue Jun 07, 2011 3:48 am    Post subject:
I like the Gamma X with a Fury.
newcrt07
Posted: Wed Jun 08, 2011 9:32 pm    Post subject:
thanks Tom.
Posted: Thu Jun 09, 2011 1:49 pm    Post subject:
The Runco 1101 doesn't have gamma adjustment like you want, neither does the HDfury3.
I use this myself: http://www.curtpalme.com/RTC2200.shtm
newcrt07
Posted: Fri Jun 10, 2011 2:28 am    Post subject:
Hey Kal. Thanks for the info. I've been looking at the gamma x also. it's a little more affordable and look a little simpler to set up. i currently have an original hdfury at the projector via a hdmi (dvi) cable running from a hdmi switcher.
Posted: Fri Jun 10, 2011 12:06 pm    Post subject:
Any of them will work. I like the RTC2200 because the gamma adjustment is a 25-turn pot instead of a slider, so you get much finer control. The slider's much easier to knock by accident.
newcrt07
Posted: Sat Jun 11, 2011 2:39 am    Post subject:
By the way, the pj does have gamma adjustment, at least according to the maintenance control selection. However, it does sternly state that any adjustments should be made by a trained technician with the proper eq. in red letters mind you.
Posted: Sat Jun 11, 2011 2:05 pm    Post subject:
It doesn't have gamma of the type that you need as I mentioned earlier. It's not a low level black boost as found in the RTC2200 or the GammaX.
My Barco Cine 8 Clone has the exact same "gamma" adjustment as the Runco 1100 since that Runco is also a Barco (it's a BArco 1209s).
I have adjusted this gamma in the projector slightly when doing a greyscale calibration but again, it's not at all the same thing as the low level black boost. It's an advanced feature for users with colorimeters to use.
