BG808s, HDFury3 and 3D-theatre is this a good setup?
NinjaAsok
Posted: Wed Jun 01, 2011 9:33 am    Post subject: BG808s, HDFury3 and 3D-theatre is this a good setup?
Got a Barcographics 808s setup working fine in 2D, 1080p with a HDFury3 module today...
Thinking of getting the 3D-theatre module.. would this be a good setup.... ?
Any special stuff to consider ?
// Regards
// NinjaAsok
Posted: Wed Jun 01, 2011 12:42 pm    Post subject:
Nope, should work fine. Your BG808s supports 720p/120 so you could run it at that higher 120Hz 3D refresh rate too instead of 60Hz. It's set by DIP switch #1.
To order see: http://www.curtpalme.com/3DTheatre.shtm
NinjaAsok
Posted: Thu Dec 29, 2011 10:19 am    Post subject:
Wondering... whats the better solotion to keep using the HDFury3 with 3D-Theatre or replace them both
with the new HDFury4 (3dfury)..
Is the 3D fuctions built into the HDFury4 as good os the once in the 3D-Theatre ?
// NinjaAsok
Posted: Thu Dec 29, 2011 7:04 pm    Post subject:
// NinjaAsok
The first HD Fury4 has yet to be shipped so time will tell..........
http://www.hdfury.com/buy-hdfury-now/
AVphile
Posted: Sat May 05, 2012 10:04 pm    Post subject:
Do you not find the geometry a bit stretched at 1080p60?
I run either 900p72 or 1080p48 and find that is still pushing it. The picture us not very linear horizontally and there is at least 5% overscan.
You might have the same problem at 720p120.
AVStefan
Old setup: HDFury3 -> BG-808s -> HD-145
New setup: JVC D-ILA -> Stewart StudioTek 130 G4
