SPL800
| Posted: Sun May 29, 2011 6:09 am Post subject: hd fury 2 power supply |
hi
i want to connect the hdfury 2 to a power supply
what are the Transformer value that i need to buy?
thanks
mc86
| Posted: Sun May 29, 2011 4:10 pm Post subject: |
post to buy-sell -- as the HDF3 I got came with both black and white wall warts and usb adapters, folks are bound to have extras and might sell for $5 for the bother plus $5 us flat rate small box. That said, I think that they can pull power via USB means 5VDC?
Matt
AVphile
Joined: 02 Dec 2008 Posts: 334 Location: Ottawa, Ontario
| Posted: Fri Jun 10, 2011 7:53 pm Post subject: Re: hd fury 2 power supply |
| SPL800 wrote: | hi
thanks |
I have a spare.
PS - you should post your location (in your profile).
_________________ AVStefan
Old setup: HDFury3 -> BG-808s -> HD-145
New setup: JVC D-ILA -> Stewart StudioTek 130 G4
| Posted: Fri Jun 10, 2011 8:38 pm Post subject: |
The power supply is 5 volts at 1 amp. Center pin negative (-).
AVphile
| Posted: Sat Jun 11, 2011 6:20 am Post subject: |
| mc86 wrote: | | as the HDF3 I got came with both black and white wall warts and usb adapters, folks are bound to have extras and might sell for $5 for the bother plus $5 us flat rate small box. That said, I think that they can pull power via USB means 5VDC? |
Yes I had HDF2 running off USB at 500ma and just built my own cable. USB on one end (plugged into a Cable box or other device) and got the small 1.5 mm connector for the Fury end (same as old Nokia cell phone) from an electronics bargain bin.
Now I have HDF3 which needs more current and came with an extra adaptor, and I have the extra USB cable that I made.
