GeorgeSong
| Posted: Sat May 21, 2011 4:54 am Post subject: XG problem help |
NEC XG110, display 1080p the view appears tailing, but display 720p is not happened, why? Help!
| Posted: Sat May 21, 2011 1:42 pm Post subject: |
I think you're talking about image wraparound, you will need a scaler between the source and the projector to fix that.
| Posted: Sat May 21, 2011 9:36 pm Post subject: |
| Curt Palme wrote: | | I think you're talking about image wraparound, you will need a scaler between the source and the projector to fix that. |
Right, or if you're using a PC as your source you can use Powerstrip to adjust your display timings.
Jeremy112
| Posted: Sat May 21, 2011 11:22 pm Post subject: |
The NEC XG series projectors are capable of displaying 1080p only with a scaler or HTPC (need to set the porch settings). otherwise it is not able to properly display 1080p.
I should note that 1080p will look more soft than 720p or 1080i as the tubes are not able to fully resolve the image (or so I have read)
