Panasonic Plasma Calibration Questions
BigDLondon
Posted: Mon May 02, 2011 11:02 pm    Post subject: Panasonic Plasma Calibration Questions
I've purchased a Panasonic 50" Plasma from Costco and it has a bad green push.I've found the service menu code.Now when I was young a TV tech told me to turn the colour off and the black and white picture will show a colour tint if the picture isn't black and white.There is a definite green tint.My question is should I turn up blue and red or turn down green ?I'll be doing this without calibration equipment. Thanks Darryl
I Love My Barco BD801s and not just because my wife tells me I do.
Posted: Mon May 02, 2011 11:10 pm    Post subject:
$400 for a trained pro ISF guy is pretty reasonable. Why not take it back to Costco if it's that bad? They have very liberal exchange policies...
No question an amateur would probably charge less to calibrate, but you'd at least need to know the service code, and an end user probably doesn't have that if there is one. Not much you can usually do in the user menus from a color balance point of view.
BigDLondon
Posted: Mon May 02, 2011 11:27 pm    Post subject:
Thanks for the advice Curt.Your Barco BD801s is still going strong.Thanks again
BigDLondon
Posted: Fri May 20, 2011 10:04 pm    Post subject:
Anyone have some advice ?Another question G-Cut versus G-drives ?Thanks BigD
Posted: Fri May 20, 2011 10:06 pm    Post subject:
I wouldn't go messing around too much with cuts & drives without a meter and software to see the results. It's fairly impossible to do by eye.
See my guide here: https://www.curtpalme.com/forum_archived/viewtopic.php@t=10457.html
Pick up a cheap EyeOne Display LT and call it a day. If you don't have time to read the 20,000 word guide then consider using ChromaPure instead as it's easier to use and walks you through a lot of it. See: http://www.curtpalme.com/ChromaPure.shtm
