Marquee rs-232 quit working
J Kildare
Posted: Thu Apr 28, 2011 3:23 am    Post subject: Marquee rs-232 quit working
Ok, so I got Irule, Iphone, and a global cache unit for rs-232 to my marquee. Get it all working and works great for a couple of months. The GC then starts losing its IP and quits all together. So I get the GC repaired, hook it all up and everything works great until I hook up the projector, then the GC just hangs up with all the Ir leds on the GC staying lit.
Question So is there a reset for the rs232 on the control board, and is all the circuitry contained to the control board itself?
Jim
Posted: Thu Apr 28, 2011 3:59 am    Post subject:
try copying all your settings with Marquee loader/controller and then initialize the pj. Reload the settings and try iRule again.
JamesAB
TV/Projector: Marquee 8000
Posted: Thu Apr 28, 2011 5:14 am    Post subject:
Are your sure it's a problem with the projector's rs-232 circuitry? I'd still be suspicious of the global cache unit.
Can you test rs-232 communication between a PC and the projector?
Can you connect the global cache unit to another rs-232 device and verify that it is working as you would expect?
