Barco 1209s: dim picture (help)
Gerbrand
Posted: Mon Apr 25, 2011 8:10 pm    Post subject: Barco 1209s: dim picture (help)
Hello,
A few nights ago my Barco 1209s was working normally.
Today the picture is suddenly very dim: you can only really see it when you look into the tubes.
Apart from that everything appears normal: diagnostics lights are all green, HV is on, fans are running etc. The menus seem more or less normal, maybe just a little bit dimmer. Also the "CONTRAST" message is normal. The brightness and contrast controls seem to be working as expected.
However, when I choose a genlocked pattern, the picture is very dim again.
What can this be? At first I thought "G2", but then I would expect also the menus to be affected.
Actually I went into the G2 menu and it also was quite dim. The leds on the green and blue neckboards are off. The one on the red neckboard is on.
My Barco has new LUGs (just a few 100 hours).
Gerbrand
BG1209s (color filtered,new LUGs!), 13000h
Bat cave
Posted: Mon Apr 25, 2011 9:01 pm    Post subject:
When you go into any menu, there's usually a different brightness and contrast memory setting. CHeck to make sure that in whatever menu you're in, the contrast or brightness isn't set really low. We know that the HV, H and V sections and the tubes are OK since the menus are fine, which really only leaves the two video boards, the quad decoder and the switching board as possible issues. I've got those in stock if you need them.
Cheers!
Gerbrand
Posted: Mon Apr 25, 2011 9:39 pm    Post subject:
I turned the set back on to check the brightness levels in the menus. While I was playing around with the contrast setting in the Barco intro screen, the picture flickered a bit and suddenly was back. So for now I am set.
But there is definitely something dodgy going on. Looking back I remember having no picture a few weeks ago, but after turning the source on and off that was solved. So I blamed the source.
Anything I can do to further track this down? Maybe inspect the boards?
BR
Gerbrand
Bat cave
Posted: Mon Apr 25, 2011 10:09 pm    Post subject:
I would reseat all boards in the set, along with the white wires that go between the two video boards.
Gerbrand
Posted: Sun Jun 19, 2011 11:04 am    Post subject:
I have reseated the boards etc. and for a few weeks the problems did not occur. Now the picture is gone again.
Would it help if I replaced the RGB input board (R762719)? I suspect the switching is not working properly (for instance: when I switch to the "BARCO" screen I do not see anything, but when I switch back to the service menu, the image is briefly visible).
BR
Gerbrand
Bat cave
Posted: Sun Jun 19, 2011 8:46 pm    Post subject:
I'd start there. If not, then I'd disconnect fully each CRT video output amplifier (CRT socket) one at a time. THe AKB circuits are on those sockets/video amps and that can affect overall brightness. I had one here the other day that completely shut down all tubes. That's the first time I've seen that.
Gerbrand
Posted: Mon Jun 20, 2011 7:44 am    Post subject:
I would expect anything in the CRT sockets to also affect the menus. Anyway, I will try to find an RGB input card.
Gerbrand
Bat cave
Gerbrand
Posted: Fri Jul 15, 2011 8:29 pm    Post subject:
Yesterday it seems the issue was promoted from "intermittent" to "permanent".
Since I have not managed to get hold of an RGB input card yet, I tried disconnecting the neckboards (both connectors). This did not resolve the issue, so for now I think I will stick with the RGB input card hypothesis. Or am I missing anything?
BR
Gerbrand
Bat cave
Ile
Posted: Sat Jul 16, 2011 10:40 am    Post subject:
Menus are inserted at switcher boards output. That indicates that driver board and neck boards are ok and problem is at switcher board.
Gerbrand
Posted: Sun Sep 04, 2011 2:48 pm    Post subject:
A few days ago I received a replacement RGB input board from Curt. Everything is working again Thumbs Up
Gerbrand
Bat cave
