Mechanical Engineer / Structural question
Sparky015
Posted: Mon Apr 04, 2011 6:11 pm    Post subject: Mechanical Engineer / Structural question
Hey guys, looking for some mathmatical expertise around the pull-out strength of a 1/2-13 hangar bolt. The wood portion is 3" in length and going into softwood. I am changing out my ceiling mount for an electric lift Chief with a finished ceiling bracket, so I was looking to use quantity 4, 1/2-13 hangar bolts into 2x8 joist supports. Thanks for the help!
~Paul
Posted: Mon Apr 04, 2011 6:49 pm    Post subject:
A half-inch lag screw is way, way overkill and you unnecessarily compromise the joist - for no good reason.
The pull-out value for a 5/16" lag screw in most lumber is something over 100 pounds per inch of thread. Increasing to 3/8" puts the value over 200 pounds per inch of thread. So, if you use even a 5/16" screw with two inches of thread in, you could hang the entire projector off one lag.
Posted: Mon Apr 04, 2011 6:59 pm    Post subject:
Looks like a 5/16" lag with 2-1/2" of embedment is good for 368 pounds according to the table in this document:
http://www.kineticsnoise.com/SeismicBook/pdfs/a7/a7.3%20-%20seismic%20design%20data%20for%20lag%20screws.pdf
The same table says a 1/4" screw with 2" of embedment is good for 272 pounds... Four 1/4" screws would put your mount capacity over 1000 pounds - probably over 5x the weight of your projector...
See why a 1/2" lag is way overkill?
dturco
Posted: Mon Apr 04, 2011 7:40 pm    Post subject:
SC covered it well. All of the charts always show the pull out from a wide flat board, think 2x8 on it side. Now the pullout changes somewhat once you only have 1-1/2 inches of material, that by putting the bolt in, you have decreased the amount of wood available for strength.
This is one of the few times where bigger is not better, in fact it is detrimental.
Do not use anything over 3/8. 5/16th is actually the best choice as it reduces the chance of splitting the wood.
Also drill a pilot hole and use soap on the threads when putting the lags in.
[Actually now that I reviewed those charts , there great and covered it better than I originally thought.]
http://www.hulu.com/firefly
Sparky015
Posted: Mon Apr 04, 2011 10:07 pm    Post subject:
thanks guys, this is the info I was looking for. I couldn't find a definitive answer, and I wanted to do the math before starting. The nice thing is that the throw puts the pj in between ceiling joists, so I am lagging into 14.5" long 2x8s going in between two joist cavities, so not only am I not lagging into house joists, but the weight is distributed over 3 joists. Anyway, thanks for helping me out with this. I was concerned with a 1/2" lag into a 2" width of wood, and you guys confirmed that concern.
~Paul
greg_mitch
Posted: Mon Apr 04, 2011 10:29 pm    Post subject:
My only advice....GO SLOW!
Sparky015
Posted: Mon Apr 04, 2011 10:34 pm    Post subject:
haha, way ahead of you! I have been pondering this for a few weeks, and making sure everything is laid out and thought of before I re-hang my investment on the ceiling. Aside from personal safety, I really like my coffee table Laughing Not really, but I do like my PJ that I've put money sweat and time into. Laughing
~Paul
dturco
Posted: Mon Apr 04, 2011 11:52 pm    Post subject:
Ok, so don't overlook what's holding the 2x8 up or in place. If they're only nailed in with a few nails....you have a weak link to deal with. Wink
greg_mitch
Posted: Mon Apr 04, 2011 11:59 pm    Post subject:
I was more referencing to actually installing the lag screws.
GO SLOW!
I broke off two after I already had them about 3/4 of the way in because I got hasty and overheated the screw and it snapped off at the head.
Sparky015
Posted: Tue Apr 05, 2011 12:20 am    Post subject:
I am planning to use 2x6 joist hangers, so not only will they be nailed horizontally to the house joints, but they will be sitting on the house 2x8 joists and nailed on top as well via the bracket. They say 2x6 joist hangers or ridge rafter hangers, but I would think they would work for 2x8s or 2x10s for that matter. They are ridge rafter hangers that work from 0 to 30 degrees. Since I am butting two braces back to back in two joist cavities, I didn't see where I had any other choice but to use hangers since I can't nail horizontally through the house joists into my 2x8s. Let me know if you guys see it differently.
GO SLOW!
Oh! That's good info to know. Did you use soap on the threads? I would be seriously upset if I broke one off.
~Paul
greg_mitch
Posted: Tue Apr 05, 2011 12:33 am    Post subject:
I pre-drilled and used only a bit of soap. I think more soap and more patience would have suited me a bit better.
Do NOT be tempted to use a power tool. Just do it by hand.
Sparky015
Posted: Tue Apr 05, 2011 12:59 am    Post subject:
Thanks Greg. I planned to double up two nuts and put them in by hand with a wrench. If they snapped like that on you, I certainly don't want to use any power tools.
~Paul
Posted: Tue Apr 05, 2011 3:13 am    Post subject:
Greg, did you pre-drill according to manufacturer spec, or did you guess? The heads shouldn't have twisted off the bolt unless the pilot hole was too small!
Posted: Tue Apr 05, 2011 12:53 pm    Post subject:
Heads can snap off if you install the lags too quickly, especially if you use a power tool to drive the lag bolt into the hole.
As mentioned, the holes should be drilled to spec for the diameter of the bolt, and then hard soap should be applied to the entire length of the lag bolt threads before it is driven into the hole. The soap lubricates the bolt so that there is less sheer stress. When you drive in the bolts, use a hand held socket wrench and do drive them in slowly to avoid sheer stress.
Also, when thinking about bolt size I often find that folks really want to over engineer their bolts for the purpose. I like to suggest a mental exercise... Imagine a single screw-eye of say a 5/16 diameter and 4" into the joist. Now imagine a rope hanging from the screw-eye that is 3 yards long. Now imagine, do you think you could hold onto that rope and hang there... I sure do. Do you think you could even swing from this same screw-eye... I do. You weigh more than half what your projector does (at least) and one screw-eye with you swinging from it can hold. I think four longer lags holding a static projector will be just fine Wink
as long as your joist is good
Sparky015
Posted: Tue Apr 05, 2011 3:58 pm    Post subject:
Thanks Craig. Sounds like 5/16-18 hangar bolts are more than enough for the application based on others experience and the numbers themselves. I'll post a picture of what my 2x8 joist support insert looks like with the ridge rafter hangars installed. I think that is more than enough for the application too.
~Paul
dturco
Posted: Wed Apr 06, 2011 3:27 pm    Post subject:
GO SLOW!
Your fine with the hangers. I could write two long paragraphs, but nevermind, joist hangers are perfect for what your doing.
