bigbri
| Posted: Mon Mar 14, 2011 4:43 am Post subject: another newbe question |
looking for your valued opinion. As I was swapping out the lens that came with my PJ for a shorter throw. I noticed the fungus that has been well discussed. But I also noticed something that seamed odd to me, But to me everything is odd. The green tube sure doesn't look like it is not mounted, for lack of a better description, square or spaced evenly. if that is true would this have an effect? [/img]
again thanks for the help
Brian
bigbri
| Posted: Mon Mar 14, 2011 4:48 am Post subject: |
all righty then, I know I'm not the sharpest tool in the shed, how do you post pics?
| Posted: Mon Mar 14, 2011 10:25 am Post subject: |
| bigbri wrote: | | all righty then, I know I'm not the sharpest tool in the shed, how do you post pics? |
Well take a digital picture or two about 800X600 max res enter your message in the open box below and then hit the "Advanced" button you will notice two oither buttons "Browse" and "Attached". You can work it from there.
mc86
| Posted: Mon Mar 14, 2011 1:10 pm Post subject: |
As you seem to "get", from a bird's eye view, the imaginary line running down the green tube, c-mount, and lens axis should be perpendicular to the plane of the screen. That said, since the green tube/lens assemblies do not have toe-in adjustment (to my knowledge), I can't imagine how it could be wonky. Surely there are 9500LC pics you can find for comparison to your machine and maybe then you can see what is different. If this geometry is not true, you'd end up mounting the projector skewed and then might run-out of toe-in adjustment for red and blue. So yes, this would likely matter!
Incidentally, as a fellow noob, perhaps it is less scolding coming from me: you might be more specific in your posts regarding the exact nature of the problem w/ relevant machine details (I had to look at your other posts to see you had a 9500LC). In addition, there is a test posting area of the forum to practice posting, as well, should you keep having troubles with embedding pics or attaching pics. I need to work on that myself!
Bests,
Matt
| Posted: Mon Mar 14, 2011 3:16 pm Post subject: |
| mc86 wrote: | I can't imagine how it could be wonky. Bests,
Matt | one of the vertical pivot pins could have fallen out.
bigbri
| Posted: Tue Mar 15, 2011 1:16 am Post subject: |
here's what I see. Photo is in direct line with tube
Ile
bigbri
| Posted: Wed Mar 16, 2011 2:03 am Post subject: |
Ile, Thanks for the reply. Would you be so kind to steer me straight on adding pics. really make a difference when trying to explain what I'm seeing. Pic worth a thousand words
| Posted: Mon May 30, 2011 6:30 pm Post subject: |
| bigbri wrote: | | Ile, Thanks for the reply. Would you be so kind to steer me straight on adding pics. really make a difference when trying to explain what I'm seeing. Pic worth a thousand words | in microsoft photo editor re-size pics to 800 x 600. At the bottom of the page choose "Browse" and find your pic, double click. Then the next button down "add attachment". You can "preview" before you post to see what it looks like.
