Marquee control program
Posted: Fri Mar 04, 2011 10:51 am    Post subject: Marquee control program
Hi!
I want to use the pc control for my marquee 7500, but it isn't work at all. I have a brand new straight wired male to female rs232 cable (checked to work with a serial mouse) I use the "rs232 IN" port on the PJ. I've tried the program on win98, win2000 and XP on two different machine, but always get an error message when I check the connection. The serial port is set to 9600bps, 8N1. CLM version is 3.1
Thanks for help!
Perry
Posted: Sat Mar 05, 2011 8:32 pm    Post subject:
Make sure that the program is addressing the right port. I'm using Windows 7 for my control program, and the serial port originally was COM11. I had to make it COM1 by going through a number of dialogues in the driver properties. The control program only accepts COM ports 1-4 so it would be an issue if the port is addressed higher than one of those numbers.
Posted: Sat Mar 05, 2011 9:51 pm    Post subject:
Thanks! I have COM1-2 named right... I think somehow the CLM doesn't communicate (well) through the serial port.
Posted: Sat Mar 05, 2011 10:07 pm    Post subject:
Hello
Some newer control programs may need newer control board firmware revisions in the projector to work right, v4.0 or later perhaps.
Posted: Sat Mar 05, 2011 10:21 pm    Post subject:
tims right the latest marquee controller 23 wont work with that old a firmware. you need a lower version. I think Tim has it right Tim?
Posted: Sun Mar 06, 2011 8:48 am    Post subject:
Oh thanks! Then can someone supply me an old version of the control software? (mine was downloaded from here)
friedwart
Location: Earth, Europe, Germany @ N 51°43'10.73'' E 14°39'05.52''
Posted: Sun Mar 06, 2011 10:33 am    Post subject:
Which version of the SW do you have? I have two versions of the Marquee Controler SW v2.2 and v2.3 The v2.2 does not work properly with my newer CLM, so perhaps it is for an older CLM.
cheers
Posted: Sun Mar 06, 2011 12:10 pm    Post subject:
We are in uncharted territory when chipping down. You want at least v3.3 with H linearity adjust, but v3.3 wants a certain IO
chip and a certain DPB U7 chip, and I am not sure if your backplane will react favorably. Ultras want minimum v4.0.
I have some older chips here but cannot be responsible if the backplane goes weird if you try them.
Posted: Sun Mar 06, 2011 12:24 pm    Post subject:
Anyway how can I know which version of control software do I have? -there isn't any clue to tell what is the version number of the control sw...
Also the librarian software doesn't work for me.
