180DVB and DMB mixing
Posted: Mon Feb 28, 2011 4:16 pm    Post subject: 180DVB and DMB mixing
I have a worn blue tube on my M7500 (R, G no wear), but I may have access to 180DVB tubes. Should I use them mixed (i.e. only the blue is DVB) if yes, do I need to modify the neckboard? (how?)
Posted: Mon Feb 28, 2011 5:56 pm    Post subject:
Hello
It should work; drill out vnb pin six with an eighth inch hole, the G2 jumper wire would go to pin six.
Posted: Tue Mar 01, 2011 6:46 am    Post subject:
And just for sure disconnect the resistor (330k)?
Posted: Tue Mar 01, 2011 10:27 am    Post subject:
If you drill out the socket for pin six, the 330k resistor will not be in the circuit.
