Pinballwizard
| Posted: Fri Feb 25, 2011 11:24 pm Post subject: Runco 990 Help |
I have a Runco 990 A.K.A NEC pg10, I bought a while back. I was in the stages of seting up the projetor, testing it out. I left the room for a refreshment and came back to the PJ and it had shut down and I smelled death.. Well I get an F8 error.. I have tryed for weeks to fix, replaced several caps and the convergence chips with no luck.. I am desperate now to get my dream projector running.. Call me crazy. but I'm determind to get this babby running.. I'm looking to see if anyone has parts that I can buy and info that would aid in the recovery. I've read that this is basicly the same PJ as a NEC PG9 plus... Are the power supply the same? In the short time I had the PJ running, I was able to find out the PJ only had 250 hrs.. the tubes are silky white.. Any ideas and help would be great....
Hi my name is Leonard and I'm a CRT aholic.
| Posted: Sat Feb 26, 2011 12:20 am Post subject: |
Does the set run without the convergence board in it? This is a plain PG chassis unless someone did a mod to the set.
Pinballwizard
| Posted: Sat Feb 26, 2011 2:01 am Post subject: |
I tryed unplugging the convergence and the projector will run a little longer but then will cycle on and off.. I did notice that the led on the defection board will not go out... the status display shows 00
Pinballwizard
| Posted: Sat Feb 26, 2011 2:17 pm Post subject: |
what would be better Curt, send you my boards or buy boards from you, I would like to repair/replace the defection and the foucus and c drive boards..and maybe buy whatever I need to turn it into a Plus..
PS I have a couple sets of tubes from a PJ 5000 will they work in the 10PG if needed down the road?
| Posted: Sat Feb 26, 2011 7:42 pm Post subject: |
It's probably better if you send me your boards. I am out of a few of the boards from the plain PG now, and until I drive to Tinman's place in the summer in LA, I probably won't be getting replacements.
