NEC 6 PG Extra convergence
digitalayon
Posted: Wed Feb 23, 2011 11:27 pm    Post subject: NEC 6 PG Extra convergence
OK...the unit is looking sharp....one question though....when manually setting up the convergence, do the tubes move both up and down as well as side to side or is it only side to side?
Posted: Wed Feb 23, 2011 11:30 pm    Post subject:
Only side to side, the metal tabs on the yoke center the raster on the tube face and shift up and down so that the crosshairs overlap.
digitalayon
Posted: Thu Feb 24, 2011 3:52 pm    Post subject:
I think I am fine then....I only had to adjust the red and blue at around 12-15 so it wasn't much...I can always shift the green down a bit as well if 15 is too high for the c-board. But wow!!! The NEC can sure punch the picture.!!!!
