Sony D50 setup help needed
eroc57
Posted: Sun Feb 20, 2011 1:24 am    Post subject: D50 issue
Hi all. I have a Sony D50 set up in my den so that it casts about a 100' pic on my wall. In order to project the pic in the right place, I had to prop up the back about an inch. This causes the pic to be trapezoidal in shape, which in turn makes it impossible to have the top and bottom perfectly focused at the same time. I've read the manuals I found online but still not sure how to correct this. Can anyone please suggest a solution? Thanks. Oh, and yes, I have a remote.
Posted: Sun Feb 20, 2011 6:15 am    Post subject:
You need to find "keystone" somewhere in the menus on the projector. This will help make the image square.
drice1234
Posted: Sun Feb 20, 2011 2:21 pm    Post subject:
If you follow the setup in this manual it will walk you step by step through the setup process and they address your issue in here.
http://www.curtpalme.com/docs/SonyD50_Install.pdf
eroc57
Posted: Sun Feb 20, 2011 3:57 pm    Post subject:
I've been through the curt palme "install" and "setup" manuals and actually have a pretty good picture, but haven't found any explanations of adjustments that fix this issue. Keystone is not mentioned anywhere that I can find. Might it be under a different name? I hate to reset and start the process all over again - it was such a pain just to get the pic this good. Any specificity on what to do to correct this would be greatly appreciated - thanks!
eroc57
Posted: Sun Feb 20, 2011 4:04 pm    Post subject:
Nevermind....disregard the previous post...found "key" and "pin" adjustments so should be good to go.
