PhoneTech
| Posted: Sun Feb 13, 2011 9:26 pm Post subject: Barco Graphics 808 goes on, but shows wierd dancing lines |
Hi all,
I bought a BG808 and finally managed to get it up the ceiling. everything is connected properly to a moome box which is connected to a HTPC with a resoltion of 1280 by 720 with negative sync on HV.
When I turn it on I can see the following lines when I look in the lenses:
http://www.youtube.com/watch?v=5lIpPLXATUA and http://www.youtube.com/watch?v=-pl0xbx4OpE
I also made a movie on the diagnotics leds and the red led on the vertical board ( I think ) is switched on.
http://www.youtube.com/watch?v=DKzgHW3bItA
I removed port 3, but that didn't change anything.
Could some one help me getting this beast working again?
| Posted: Sun Feb 13, 2011 11:34 pm Post subject: |
That is normal in the sense that your HV, H and V deflection are working, and there SHOULD be an image on the screen.
What you're seeing is the AKB line which is seen on all Barcos with no signal present.
Try video or Svideo input 1 or 2) to see if that works. You could have a problem on the RGB switcher card, or something's not right with the input. H and V sync cables reversed, the computer defaulted back to positive sync, or ?
PhoneTech
| Posted: Mon Feb 14, 2011 11:07 am Post subject: |
Managed to get the setup screen up and running this morning. I bought the beamer with a defective port 3, but still have an BD 801s with a working port 3.
Can I use the 801s port 3 board in de 808? I will keep trying to get a picture through port 5 using powerstrip. I need to check my Moome box if it is set to the right sync but I can't seem to find the manual for the external moome box (DVI and component to VGA).
PhoneTech
| Posted: Mon Feb 14, 2011 10:16 pm Post subject: |
I have a space SMPS and a spare port 3 board and I tried both, but with every combination, the projector starts up, and then shuts down after about 10 seconds.. It does that 3 times after completely shutting down. Is this a familiar problem?
| Posted: Mon Feb 14, 2011 11:02 pm Post subject: |
I thought the setup screen was working? Now the set is shutting down?
When the set shuts down like that, some fault in the set is triggering the shutdown. Most likely it is convergence tray, H or V board or SMPS related.
Before you start doing more stuff at random, is the red SF light on on the G2 board?
PhoneTech
| Posted: Mon Feb 14, 2011 11:08 pm Post subject: |
The red light on the G2 board is on.
PhoneTech
| Posted: Tue Feb 15, 2011 8:16 pm Post subject: |
Ok. Tonight I compared the wirings of the boards to a picture I have taken earlier, and I accidently connected the port 3 board to the vertical board instead of the switcher board. Even with the wiring corrected, I still get the red led on the g2 diagnostics board turned on and the projector starts for 10 seconds, and then shuts down 3 times. Does this mean my vertical board is broken?
| Posted: Tue Feb 15, 2011 10:15 pm Post subject: |
Yes, you smoked the V board. It will die instantly if you connected that wire incorrectly. I've got boards at $50 plus shipping.
PhoneTech
| Posted: Wed Feb 16, 2011 2:27 pm Post subject: |
I am hoping to get a board here in the Netherlands, because that might be faster.
I understand the same board is used in the Barco Graphics 801s, 808 and 808s models?
PhoneTech
| Posted: Wed Feb 16, 2011 3:14 pm Post subject: |
I just read that I could use a V board from a Barco Data 801s in a 808 graphics, but the blanking controls might not work.
http://www.avsforum.com/avs-vb/showthread.php?t=922358
Partnumber from my 801s: R762269
Partnumber from my 808: R7622685
I this safe to do? Won't I break other boards?
I know for sure that I won't connect port 3 to this board again! In the mean while, if I can't find a V board somewhere here in holland, i'll order one from Curt.
Decibel
Joined: 31 May 2007 Posts: 904 Location: Roma - Italia
| Posted: Wed Feb 16, 2011 3:26 pm Post subject: |
| PhoneTech wrote: |
Partnumber from my 808: R7622685 |
I think that I have one but I'm not sure, I'll check availability tomorrow.
_________________ Domenico (Barco fan!)
Decibel
| Posted: Thu Feb 17, 2011 2:38 pm Post subject: |
| PhoneTech wrote: | | Partnumber from my 808: R7622685 |
| Decibel wrote: | | I think that I have one but I'm not sure, I'll check availability tomorrow. |
Yes ... I have working R7622685 and other 808 spares.
