| Posted: Fri Feb 11, 2011 11:58 pm Post subject: I need an anti-reflective coating for plexiglass/lucite |
Preferrably spray-on, what can you tell me?
jeffslife
| Posted: Sat Feb 12, 2011 12:25 am Post subject: |
Coating for what purpose?
| Posted: Sat Feb 12, 2011 12:33 am Post subject: |
Hello
To minimize or eliminate unwanted reflections, nothing to do with projectors.
zGman
jask
| Posted: Sat Feb 12, 2011 4:49 am Post subject: |
Do you need to retain the transparency? how consistent does the finish need to be?
Gerbrand
| Posted: Sat Feb 12, 2011 10:50 am Post subject: |
| zGman wrote: | As you may know - AR coatings for lenses are vacuum deposited 1/4 and 1/2 wavelength
thick layers of different refractive index materials which in the right combination create
a boundary condition which does not allow reflection. These can be quite complex, and
have some issues of bandwidth and entry angle.
Basically this means you cannot spray it on yourself...
I would not worry too much about the angular dependence and bandwitdth. Wide-bandwidth coatings in the visible range are available. They are used, for instance, on photography lenses.
Gerbrand
_________________ BG1209s (color filtered,new LUGs!), 13000h
Bat cave
| Posted: Sat Feb 12, 2011 1:52 pm Post subject: |
| jask wrote: | | Do you need to retain the transparency? how consistent does the finish need to be? |
Yes, very transparent and even across twenty inches of plexiglass, for an lcd screen.
David_Web
| Posted: Sat Feb 12, 2011 5:56 pm Post subject: |
You could try contacting the manufacturer directly, if there is something that works they should probably know of it.
http://www.arkema-inc.com/index.cfm
Or maybe these guys could help.
http://www.eplastics.com/
Maybe a thin layer of anti-reflective/refractive treated material could be laminated on top of the Plexiglas.
_________________ SNR of people are ridiculously low.
jask
ervinburch Guest
| Posted: Sat Dec 22, 2012 4:16 am Post subject: |
There is no coating requires for plexiglasses. I think it can be used without coating easily.
non glare plexiglass
| Posted: Sat Dec 22, 2012 3:12 pm Post subject: |
Well how about that. A spammer whose spam actually pertains to the threads subject..... Interesting... cudos on the effort...
| Posted: Sat Dec 22, 2012 9:25 pm Post subject: |
| macgyver655 wrote: | | Well how about that. A spammer whose spam actually pertains to the threads subject..... Interesting... cudos on the effort... |
Oh my god that's too funny! I almost feel sorry for deleting his ass. Almost
| Posted: Mon Dec 24, 2012 11:40 am Post subject: |
Take a piece of plexiglass and lay it down on a flat surface. Get some 600 grit wet/dry sand paper and put it on a dual action sander. Mix up a solution of soap and water. (just enough soap for lubrication). Then work your way around the plex with the sander to just take off the gloss. Then hold it up to the LCD you wish to use and see if it provides the effect you want. You can even go finer then 600.
_________________ Chip
