vim 02p red channel out !!
dvh99
Posted: Fri Feb 11, 2011 12:48 pm    Post subject: vim 02p red channel out !!
could it be that the sd5401 is damaged and the red is out.
there is no internal video and no external.
cranking the drive and g2 makes the raster light faintly.
swapping video cables from red to green on the vim makes the red light so it is the vim.
Posted: Fri Feb 11, 2011 1:15 pm    Post subject:
Check the AD 834.
dvh99
Posted: Fri Feb 11, 2011 1:29 pm    Post subject:
nope the voltages on pin 4 and 5 check out ok.
6volts or so on a white field.
i was putting a hdmi cable from the ps3 in the vim while the vim was connected with the extension card, after that red went out Sad.
Posted: Fri Feb 11, 2011 4:09 pm    Post subject:
The question is have you lost video or gain/drive on red. Can you test at test pins TP14, TP15 and TP16 for gain control?
Posted: Fri Feb 11, 2011 4:29 pm    Post subject:
When using the extension card do you have anything under the vim to isolate it from the chassis? if not you might have shorted something out. and that could be anything!!
And do as mac advises to narrow down which function is lost.
dvh99
Posted: Sun Feb 13, 2011 7:42 am    Post subject:
tp checks out ok
i have lost video and the internal video as well.
mac any ideas?
Posted: Sun Feb 13, 2011 3:26 pm    Post subject:
I have lots of ideas.....however, I think any further conversation would fall under Curts business and I wont infringe......sorry.
Very Happy
Posted: Sun Feb 13, 2011 4:03 pm    Post subject:
If you're stuck, I can repair it.
Cheers!
dvh99
Posted: Sun Feb 20, 2011 6:43 pm    Post subject:
scooped a 02p vim for 15 euro Mr. Green .
do not throw names at me like........... vulture Cool .
dvh99
Posted: Sun Feb 20, 2011 6:57 pm    Post subject:
who was bidding on the hvps and lvps Evil or Very Mad
friedwart
Location: Earth, Europe, Germany @ N 51°43'10.73'' E 14°39'05.52''
Posted: Sun Feb 20, 2011 7:07 pm    Post subject:
€15,50 Smile
Cheers
dvh99
Posted: Sun Feb 20, 2011 7:08 pm    Post subject:
hi is it your vim?
dvh99
Posted: Sun Feb 20, 2011 7:09 pm    Post subject:
where are you located koln?
friedwart
Posted: Sun Feb 20, 2011 7:17 pm    Post subject:
dvh99 wrote:
hi is it your vim?
no, it isn't. But I know the seller and watched the auktion.
dvh99
Posted: Thu Jun 09, 2011 4:11 pm    Post subject:
to get back on this.... my vim wasn`t broken!
because of the numerous times i took out the vim and put it back in, the connector on the motherboard is damaged so i sometimes do not have a red channel.
upon reinserting (sometimes this takes a couple times) the red is back.
how hard is it to get to the soldering points of the connector where the vim goes?
Posted: Thu Jun 09, 2011 4:47 pm    Post subject:
Hard. You need to take out about 100 screws to get to the backplane.Sad
dvh99
Posted: Thu Jun 09, 2011 5:03 pm    Post subject:
i was afraid of something like this et the 100 screws is not exaggerated of course Smile.
so i take 3 tubes out the the upper board and then the backplane?
Posted: Thu Jun 09, 2011 5:04 pm    Post subject:
Actually it's pretty close.
To get at the backplane, the whole set needs to come apart. Literally.
Do it, it's good exercise. Very Happy
I've done it twice.
dvh99
Posted: Thu Jun 09, 2011 7:41 pm    Post subject:
wanna bet i will have at least 25 screws left Mr. Green
Posted: Thu Jun 09, 2011 7:55 pm    Post subject:
I've done the tear down before and had no screws left, i actually needed to find two more, some must have been missing.
