Convergence help please.
Wognose
Posted: Mon Jan 31, 2011 2:13 pm    Post subject: Convergence help please.
Hi, I am hoping someone can help me, I am trying to converge my G70 that I have recently upgraded with moome v3 and I am having some trouble. I have it set to RGB input, when I try to converge the screen goes full size, alot larger than my screen size which makes it difficult to converge the entire screen. Is there a way I can make the screen smaller to converge? RGB size doesn't seem to work when converging in RGB mode.
jeffslife
Posted: Mon Jan 31, 2011 8:59 pm    Post subject:
What do you mean it doesnt seem to work ? you mean it wont change size ? bigger or smaller ?
We are ALL job creators !
jeffslife
Posted: Mon Jan 31, 2011 9:42 pm    Post subject:
What is your "SIZE" setting along the bottom row? IT should be set between 180-200 out of a 0-255 range.
Curt taught me that.
Posted: Mon Jan 31, 2011 9:58 pm    Post subject:
First, if the convergence pattern is going much, much larger than your screen, it sounds like your physical installation (the throw, specifically) may be wrong. How big is your screen and how far away is the front of the projector (lenses) from the screen?
Next, are you adding a new resolution to your setup with the installation of the Moome card? If so, you'll probably want to do a setup from scratch vs. just tweaking the size.
Finally, RGB size and shift is to control the size of the active area - the input signal - not the raster or convergence pattern. It's what you do AFTER the convergence is set properly. As Jeff mentioned already, you'll be using the "SIZE" convergence control in "service man" mode to change the size of the raster.
