JamesAB
Joined: 15 Jan 2011 Posts: 56 Location: New Hampshire
TV/Projector: Marquee 8000
| Posted: Sat Jan 22, 2011 7:12 pm Post subject: GT17 lenses with a 72" screen? |
I'm looking at 9500LC ultra projectors and comparing the lens choices.
In the user manual (I know it's just a starting place that tends to "overestimate" throw distance) the minimum screen width recommended starts at 78" for HD10E lenses and a minimum screen width of 91" for HD10 GT17 lenses.
Would I have focus or other problems using either lenses in a 9500LC ultra projecting on a screen that is only 72" wide?
James
trebortaergeht
| Posted: Sun Jan 23, 2011 6:33 am Post subject: |
I have a 9500 with gt17's on a 71" wide screen and it's slightly soft. I'm on the bottom of the focus range with only about a 1/16 of an inch of adjustment left
| Posted: Sun Jan 23, 2011 7:07 am Post subject: |
The GT-17 is a great lens... Can you afford a larger screen ?
JamesAB
| Posted: Sun Jan 23, 2011 4:34 pm Post subject: |
| Nashou66 wrote: | Id use HD10L's if I were you for that screen size.
Athanasios |
I saw the HD10L's were recommended for screens up to 71". I wonder how hard it would be to find a set of HD10L's?
It's odd that the reference table in the manual has a gap between 72" and 77" screen widths. That's why I'm glad to get feedback from people here with real world experience.
| trebortaergeht wrote: | | I have a 9500 with gt17's on a 71" wide screen and it's slightly soft. I'm on the bottom of the focus range with only about a 1/16 of an inch of adjustment left |
That's one of the things I was worried about. Can I ask trebortaergeht, what is your throw distance?
| Tom.W wrote: | | The GT-17 is a great lens... Can you afford a larger screen ? |
I can afford to buy a bigger screen, but I wouldn't have room for it.
My current screen is electric and mounted above the ceiling. I may be able to expand a few inches when I upgrade from a 4:3 screen to a 16:9 screen. Due to the layout of the room the absolute maximum width for the viewable area on a new screen would be 84".
Right now I have a Marquee 8000 that drops down from the ceiling using a SRS-4 lift. Luckily, when I set this up years ago I installed the lift on a steel track so it won't be too difficult to move the whole business to adjust the throw distance between 90" and 110".
Thanks for your feedback and suggestions,
James
trebortaergeht
| Posted: Sun Jan 23, 2011 4:54 pm Post subject: |
From screen to lenses my throw distance is 91".
crteaman
| Posted: Fri Jan 28, 2011 10:59 pm Post subject: |
My 9500/V1 had GT 17's and I was using a 72" screen...I was getting close to the end of adjustment..but was by no means bottoming out...
I also set one up on a 69" screen once...still not bottomed out...
But I will say I liked to use every bit of my phosphor width...so my units (and on my customers installations) were always mounted real close...and opened out...
When Henry (a few years ago now) ordered a brand new 9500 Ultra for himself...Brian and Nathan (VDC) insisted he didnt have GT17's...but instead almost insisted he chose HD 10E...when the unit was nice and run in...a few hundred hours...we spent 'Hours' swapping lens..to see if we could prove/debug any myths...
We could see NO perecptable difference between the 10E and the 17 on his 80" screen...10L's however are not great...they are not quite as sharp in the centre...and even less sharp around the screen border.
| Posted: Fri Jan 28, 2011 11:01 pm Post subject: |
Hello
I have either HD10Ls or GT17s for the 9500 we talked about.
