Reality 909 issue
Decibel
Posted: Tue Jan 18, 2011 10:56 am    Post subject: Reality 909 issue
My friend have a Reality 909, see these pictures (out of convergence)
I2C diagnostic menu show a failure
Any suggestions?
Domenico (Barco fan!)
Ile
Posted: Tue Jan 18, 2011 1:08 pm    Post subject:
If turning convergence off (midposition), removing all memory blocks and reseating Hdef card doesn't help, maybe it's bad IC202 (TDA8444T) in Hdef card as diagnostic suggest.
Decibel
Posted: Tue Jan 18, 2011 1:47 pm    Post subject:
Thank you Ile
My friend has reset convergence to midposition, I don't know if has deleted all memory blocks.
I will ask him.
Posted: Tue Jan 18, 2011 1:54 pm    Post subject:
I have seen this before, but it was the SMPS that was bad, causing a false H shift error code.
Decibel
Posted: Tue Jan 18, 2011 3:07 pm    Post subject:
Thank you Curt.
A question: which SMPS could be compatible for try to swap?
Posted: Tue Jan 18, 2011 3:12 pm    Post subject:
Nothing other than one out of a Cine 9/909. The only parts in the new chassis that is compatible with the older BArcos are the HV section and the video switching/quad decoder boards. Everything else is different.
I can repair it here though.
