NEC PG6 xtra - Dim Video, normal menus
mistagreg
Posted: Sun Jan 09, 2011 6:01 am    Post subject: NEC PG6 xtra - Dim Video, normal menus
Got this projector for $100. It was in someones basement for a while. I finally got around to hooking it up. The video is very dim as well as test patterns. The menus however are normal. Brightness is set at 60; contrast is 75. Any suggestions?
Posted: Sun Jan 09, 2011 8:55 am    Post subject:
I don't know for sure, but play with AKB or color temp. What about RGBHV?
mistagreg
Posted: Sun Jan 09, 2011 3:09 pm    Post subject:
Turned AKB on/off. Color Temp is at 50%. I did notice that the RGBHV connections seem to be a bit wacky. The picture going up continuously like it needs a vertical hold knob. When I fiddle with the connection it get better.
-Greg
Posted: Sun Jan 09, 2011 4:08 pm    Post subject:
Do you have it setup up on a registered entry?
mistagreg
Posted: Sun Jan 09, 2011 6:27 pm    Post subject:
yes, i've labeleed it HD:7210p. Should I delete and redo?
-Greg
Posted: Sun Jan 09, 2011 6:40 pm    Post subject:
Have you adjusted the white balance in that entry?
