need help in contro NEC XG 1100 pls.
seong6788
Posted: Sun Dec 26, 2010 4:15 am    Post subject: need help in contro NEC XG 1100 pls.
i want to setting up my XG 1100 but i'm no remode,can i use only rs-323 to setting up my XG?if can,can tell the way i can download the software.
jarseneau
Posted: Sun Dec 26, 2010 4:26 pm    Post subject:
You can, using the XG control software for PC found here.
Jerry
seong6788
Posted: Mon Dec 27, 2010 10:43 am    Post subject:
okkkkk Very Happy Very Happy ,thks lot.may i know is that u are use xg b4?can give any tips for xg for they picture quality or in setting what i need to do or must carefully?what conection are ur 1st choice and 2nd,3rd choice.btw realy thks for ur reply.
seong6788
Posted: Fri Dec 31, 2010 7:45 am    Post subject:
same problem again is when i pluk in XG then click the icon of Pc contro for XG and he show
[! COMMUNICATION DEVICE OPENING FAILURE]
Hardware not present
what can i do now?i already try to turn off the XG and my Pc,after i turn on again XG and my Pc but still can not.my connection is remote(15p-15P)in XG link to my pc.so what i need to chek or seting in XG?pls tech me same...
jarseneau
Posted: Fri Dec 31, 2010 6:45 pm    Post subject:
A straight through 15 pin cable will not work. You need to make the serial cable shown in the instructions. Be sure you are using a valid port on your PC and set the baud rate to 9600 initially.
Jerry
jarseneau
Posted: Fri Dec 31, 2010 9:00 pm    Post subject:
Setup advice... Avoid adjusting ANY pots on the boards with the possible exception of FOCUS.
Leave the KELVIN adjustments as they are until you have written down the before settings and proceed with caution.
Try to converge the image as best you can before resorting to ZONE.
If you suddenly have a black or bright line in the middle of the image, you have used too much ZONE, LIN-BALANCE, or PIN-BALANCE.
When doing mechanical ASTIG, pre mark the rings so you can start over by 'scribing' a sharpee pen mark across the edges of the 6 rings with 2 adjacent lines to make a unique mark.
Get the mechanical setup correct early in the process. The distance to the screen should be 5%-10% closer than the manual states for best phosphor usage.
Jerry
seong6788
Posted: Sat Jan 01, 2011 5:43 am    Post subject:
yup 1 more i want to know is in XG have fectory reset?
jarseneau
Posted: Sat Jan 01, 2011 9:01 pm    Post subject:
The factory reset is a highly guarded secret that I've never learned but seems just as well considering the risk of making the XG non-functional. Hitting CTRL+NORMAL does pretty much the same thing anyway.
Jerry
jarseneau
Posted: Sat Jan 01, 2011 9:31 pm    Post subject:
Oops, forgot you don't have a service remote. The alternative is to center all convergence/alignment controls in the PC controls.
Jerry
seong6788
Posted: Sun Jan 02, 2011 2:53 am    Post subject:
yes thks for ur tech me,yesteday i already done my setting by usesing remode wahhh so fast can done all setting(my frns help me to find the remode from he frns last time ownre of XG)thks for u and curtpalme.but now again have problem i can't save my setting in my XG.in starting i can save my setting just 2 or 3 time only but till i'm close wif done my job when i press the "store" he show me (CAN NOT STORE NO ENTRY Crying or Very sad ),i've try to enter a new input at input list but also can not be stor my setting i already try 5 or 6 time,so are u have it's problem b4?is any data can we delete?but the XG pic is so nice for me play in 1080p Very Happy ,i'm planing up to HDMI 1.4 play in 3D it's than same nice picture?sorry my engelish not so will...
jarseneau
Posted: Sun Jan 02, 2011 3:41 am    Post subject:
Do you have a signal coming in when you try to save an entry? An incoming signal is required because the projector uses the scan rate info as part of the entry creation.
If you do have an incoming signal, the 'signal entry' is made by first hitting the ADJUST button, then choose SIGNAL ENTRY from that menu and follow the prompts from there.
Jerry
seong6788
Posted: Sun Jan 02, 2011 6:40 am    Post subject:
thks lot i will try by to day late.btw happy new yr.
seong6788
Posted: Mon Jan 10, 2011 8:58 am    Post subject:
yap i'm done my setting,thks for ur help the XG projec so nice (for me)in 1080p.but in side focus is not in perfect,how i know is when i play movie is in center projec is clear but just in side is not clear so what can i do?is that i need to direc ajust the lens i've this but dose work so what can i do? may i ask u,u are use 1.3a hdmi or use 1.4a 3D?
kschmit2
Posted: Mon Jan 10, 2011 5:11 pm    Post subject:
check the compatibility of your PC Control Software with your XG's serial number on this page first:
http://www.curtpalme.com/NECXG_Compatibility_PC_Control.shtm
jarseneau
Posted: Mon Jan 10, 2011 6:56 pm    Post subject:
So far I only need HDMI 1.3
For you focus tweaking, we need to know if the focus is out due to the lens or is it electronic adjustment. Each lens has 2 wingnuts, one to lock the center and located toward the back of the lens and the other toward the front which locks the edge. The center adjustment is straightforward where you can see the focus pattern get sharpest at in the picture center. The edge adjustment is different in that the picture edges on the left and right will look smeared or hazy when out of adjustment. The other difference is that the wingnut moves as you change center focus but when you adjust edge, the wingnut is stationary while the body of the lens moves.
Jerry
