Gerbrand
| Posted: Tue Dec 21, 2010 7:16 pm Post subject: BG1209s: dodgy vertical scan switch |
Hello,
Today I finally mounted my retubed BG1209s on the ceiling. However, when trying to switch the projector from floor projection to ceiling projection, I found that the little wire underneath the spring had disappeared. This means that the switch no longer works properly.
As a work-around I fixated the switch in what I think is the correct position using some tape. However, the projector responds with a "scan-fail" (the HV won't come on). This is the "not pressed" position. When I put the switch in the "pressed" position the projector works, but of course this is not the setting I want.
What would you suggest? Is there a way I can test that the switch is in the proper position and then fixate it? Or should I get myself a new deflection control board from Curt?
Regards
Gerbrand
_________________ BG1209s (color filtered,new LUGs!), 13000h
Bat cave
Ile
| Posted: Tue Dec 21, 2010 7:35 pm Post subject: |
One of my 808s scan switches miss whole spring and that pin, because that plastic button have cracked.
If I remember correct, working position is bit inside from full out. I eyeballed position from good switch and it seem to work ok. I was meant to glue it or something but newer bothered since it works.
| Posted: Tue Dec 21, 2010 9:24 pm Post subject: |
I've used the tape method as well. Many of those switch springs fail, or more correctly, fall off the end of the switch. I spent 1/2 hour once trying to put it back, and gave up. If you're not moving the projector, just use the tape. I do have spare yoke boards or can desolder a working switch if you want.
| Posted: Tue Dec 21, 2010 10:25 pm Post subject: |
10 to 1 that was duct tape with Curt being from Canada and all......
| Posted: Tue Dec 21, 2010 10:28 pm Post subject: |
Hey, don't make me give away any of my Macgyer type solutions. That's how I get to charge the big bucks!
Gerbrand
| Posted: Tue Dec 21, 2010 11:23 pm Post subject: |
Thanks. I will try the tape method some more (just need to see where I can get some Canadian duct tape around here).
For some reason, eyeballing the correct position did not work for me though. Can I just try? Ie switch off the projector, move the switch a bit, turn it on to see if it works, repeat...
Thx,
Gerbrand
Bat cave
