Romberth
| Posted: Thu Dec 16, 2010 10:28 pm Post subject: Using 1209 tubes in a 1209s? |
Hello.
I need to know if it is possible to put 1209 tubes in a 1209s? The tubes in the 1209s are toasted but the housings are usable.
The 1209 tubes are in their housing too. I believe that a housing swap is necessary if I want shiempflugs... But I am not sure that non Lugs will fit in a 1209s.
Thx for your help.
| Posted: Thu Dec 16, 2010 11:42 pm Post subject: |
They should fit just fine. You will need to swap the housings and buy some fresh glycol. Also let the new silicone sealant cure for about a week before putting in the glycol.
arbey
| Posted: Fri Dec 17, 2010 8:03 am Post subject: |
| Quote: | | They should fit just fine. |
That's what i thought.
But last time i retubed a 1209s with new LUG"s, I had to do a pin-out modification to the tubes.
regards
_________________ crttime
| Posted: Fri Dec 17, 2010 1:11 pm Post subject: Re: Using 1209 tubes in a 1209s? |
| Romberth wrote: | Hello.
Thx for your help. |
The post said non-Lugs but never said what tubes were actually being used........
Romberth
| Posted: Fri Dec 17, 2010 4:13 pm Post subject: |
Thanks for the answers guys.
Maybe I wasn't clear enough...
On one side : One working 1209s with toasted Lugs
On the other side : One non-working 1209 with perfect tubes (non Lugs).
The idea : installing the tubes from the 1209 into the 1209s.
If I understand well, Tom says it is possible. What needs to be done is : Taking out the toasted Lugs from the 1209s housing, then install the 1209 tubes in these 1209s housing, then installing them in the 1209s.
Am I correct ?
tromatus
| Posted: Fri Dec 17, 2010 9:17 pm Post subject: Re: Using 1209 tubes in a 1209s? |
| Tom.W wrote: | | Romberth wrote: | Hello.
The post said non-Lugs but never said what tubes were actually being used........ |
i think his tubes are P19LCP07
Romberth
| Posted: Fri Dec 17, 2010 11:32 pm Post subject: |
Thx Tromatus.
That is correct, tubes in the 1209 non"S" are P19LCP07. So can they be installed in the 1209s providing that we swap housings?
Decibel
Joined: 31 May 2007 Posts: 904 Location: Roma - Italia
| Posted: Sat Dec 18, 2010 2:17 am Post subject: |
| Romberth wrote: |
That is correct, tubes in the 1209 non"S" are P19LCP07. So can they be installed in the 1209s providing that we swap housings? |
I think yes, i know that 1209s chassis is the same of 1209 (non s) and 1209s neckboards could be compatible with p19lcp's.
_________________ Domenico (Barco fan!)
Romberth
| Posted: Sat Dec 18, 2010 7:24 am Post subject: |
Thank you Decibel.
| Posted: Sat Dec 18, 2010 7:25 am Post subject: |
| Romberth wrote: | Thanks for the answers guys.
Am I correct ? |
The P19LCP07 should work fine with no modification to the neck boards.
Romberth
| Posted: Sat Dec 18, 2010 1:16 pm Post subject: |
Thx Tom for confirmation.
