Revox
| Posted: Wed Dec 15, 2010 1:28 pm Post subject: HD 145 Questions - AGAIN and.... again... |
Hey,
i just bought a Barco Vision 701s for 10€ with nearly new tubes, ok shipment is a little bit more expensive than 10 Bugs but .
I got the Idea to change the HD 145 Lenses to HD 6 cause there might be not such a big difference on the EL Focus Barco.
The Question: is there realy big difference on a Marquee 8500?
I red a lot in the last 2 Hours, but everyone is talking about Colours (and the HD 144). The Lenses on the Barco are HD 145 ones and unfiltered. I am Using PT 65 Lenses on my Marquee so they are a little bit sharper than the HD 8.
So my question is, do Pictures in this forum exist which give my the motivation to build Lens adapters?
The problem is that i am not able to spend 150€ on the "original" adapters, so i must find ways to build it out of wood or aluminium by myself. So I expect at least 10 Hours of Work.
Do the Throw Distance changes a lot?
dturco
| Posted: Wed Dec 15, 2010 3:06 pm Post subject: |
What the hell are you asking?
http://www.hulu.com/firefly
Revox
| Posted: Wed Dec 15, 2010 3:09 pm Post subject: |
Sorry as you notice i am not speaking english as a native language.
I am searching for the topic HD 145 VS. HD 8 lens. I red a lot of 144 Lenses, but i cannot gues if its worth work to change from PT 65 to HD 145.
virusc
Joined: 11 Apr 2007 Posts: 358 Location: Massachusetts
| Posted: Wed Dec 15, 2010 3:15 pm Post subject: |
going from HD-8 to HD144/145 will make a big difference in focus and color (especially if you get the color filtered 144/145's) HD-8 is not that good of a lens. HD-6 is fine for a barco701 like you said.
dturco
| Posted: Wed Dec 15, 2010 3:18 pm Post subject: |
I think Revox is talking about modify the Marquee with the lenses from the Barco.
Revox
| Posted: Wed Dec 15, 2010 3:33 pm Post subject: |
So is HD8 as "bad" as a PT 65? I noticed a difference between those two lenses.
Is the HD 145 as good as the HD 144 (only the sharpness). I read in an old post (2005) of the AVS Forum, that the HD 145 is not as good the HD 144 (both filtered...).
I think those question do exist all around in this Forum, but am i right that noone has taken pictures of his change?
As i found right now is, that the Picture will be a little bit smaller, excelent for my room.
akajester
| Posted: Wed Dec 15, 2010 3:46 pm Post subject: |
I have not seen picture quality comparisons anywhere of these lenses. My limited understanding was that the HD144 and HD145's were very similar. Making the change to color filtered lenses would make the most difference in your system.
Revox, you should fill in your profile to indicate what country you're from. Maybe someone locally could help you out too.
Dale
Revox
| Posted: Wed Dec 15, 2010 3:57 pm Post subject: |
I red a interesting thread out there:
My Marquee has got nearly mint Tubes, so i am able to use nearly the full phosphor area.
The Guy out there says there might be a problem with "darkend" corners.
http://forum-display.com/discussion/15747/2/best-resoultion-for-a-bg808/
My Glycol is already coloured, so the colours are near the "optimum" of the sRGB room.
So i know there is a hype out there of the HD 144 and HD 145 Lenses, but i did not find posts that describe the changes so, let me say "academic" , as things in the marquee modification thread.
Greetings from Berlin, Stefan
| Posted: Wed Dec 15, 2010 3:59 pm Post subject: |
jester is right. 144 and 145 are nearly identical, with slightly different focal lengths. Both are superior to HD8 sharpness-wise, but it's not a HUGE difference. The big win with these lenses on a Marquee is color filtering -- but you don't have filtered lenses so no gain there.
Meanwhile you'd have to buy or make adapters, move the projector to compensate for the different focal length, etc. If it was me, I wouldn't bother.
Maxing out the phosphor usage gets you out toward the edges of the lenses, and might reduce brightness and sharpness in the corners. Not 100% sure on that one.
napos
Joined: 21 Oct 2006 Posts: 164 Location: Athens, Greece
| Posted: Wed Dec 15, 2010 5:45 pm Post subject: |
Hello Stefan,
Did you get your Marquee from Uwe of Spatz-tech?
_________________ Marquee 9500LC Ultra with MP mods, Moome HDMI 1.3 card, Lumagen Radiance XS, Oppo 83 BluRay, Toshiba XE-1 HD-DVD, HTPC with Media Player Classic.
| Posted: Wed Dec 15, 2010 6:52 pm Post subject: |
Some new AC marquee's come stock with clear HD 145's. They are definitely better in focus on the edges than the HD8's.
I think if your looking for the best upgrade for an 8 inch marquee is to find a set of 8 inch LC housings and a set of any HD 10 lens.
But making an adaptor is not hard if you have access to a CNC machine. I would only use aluminum, wood and plastic/Acrylic will expand and contract too much and affect convergence stability.
Revox
| Posted: Wed Dec 15, 2010 10:04 pm Post subject: |
No, i got the Marquee from someone who was selling "old university Stuff" who was not deep into technics.
I got 2 nearly mit Marquees for 400€. But the tubes were a burned a little bit (after 800hours!).
I think i try it definitively with an testbuild on the green lens.
Cause i am a student with, let me say other hobbys, investing to much money in the home cinema is not possible.
In the moment i don't have the possibility to know someone whos acsess to a cnc machine. Every one is just studiing and calculating...
1031
