Wyseman
Joined: 16 Apr 2010 Posts: 27 Location: Tolentino (MC) Italy
| Posted: Fri Dec 03, 2010 12:52 pm Post subject: Moome HDMI V1.3 processor |
Hello, i got this moome ext box from a friend here in Italy, but i can't find any documents or manual to download.
The box has one hdmi input, 4 leds: det, 12bit, 10bit, and a clear one wich becomes red when connected.
I tried it on my bg808s with PS3, but i don't know how to set it. What about the dip switches? The Gamma control changes almost nothing even after 20 turns on 25, while the red led keeps blinking!
Can somebody help me please?
Thank you very much!
Wyseman
| Posted: Fri Dec 03, 2010 6:54 pm Post subject: |
Thanks for your help Nashou, but i can't find any info on the dip switches, only the setting to set the signal to 0-255.
I would also like to identify wich kind of box is the one i have.
It has only one hdmi input, and there is "hdmi v1.3 processor" written on the box.
Is it v1, v2?
Ron W
| Posted: Sat Dec 04, 2010 12:54 am Post subject: |
| Wyseman wrote: | Thanks for your help Nashou, but i can't find any info on the dip switches, only the setting to set the signal to 0-255.
Is it v1, v2? |
If it has only one HDMI input then it is a V1 model.
Wyseman
| Posted: Sat Dec 04, 2010 8:34 pm Post subject: |
Isn't V1 jus hdmi1.2 compatible? On the box i have there's written HDMI 1.3! Anyway, where can i find manuals? Just to compare the two versions and to have some more infos.
Thank you all!
moome
| Posted: Mon Dec 06, 2010 1:01 pm Post subject: |
| Wyseman wrote: | Isn't V1 jus hdmi1.2 compatible? On the box i have there's written HDMI 1.3! Anyway, where can i find manuals? Just to compare the two versions and to have some more infos.
Thank you all! |
Dear Sir:
please check the link:http://www.moomecard.com/index.php?option=com_content&view=article&id=6&Itemid=15
it can help you your problem,thanks.
Moome
