opv
Joined: 18 May 2010 Posts: 202 Location: Emek Hefer,Israel
| Posted: Fri Dec 03, 2010 8:49 am Post subject: two different configuration for one resoultion, possible? |
I own a BG1209S connected to a popcorn like media streamer at 1080P@50Hz resolution.
The size of the picture in 16:9 aspect movie is big enough, however the picture in wider aspect ratio movies isn't.
I want to be able to use a larger H-size setting for the wider movies. I don't mind switching configurations manually for each movie.
Is it possible to save two different configurations on the PJ memory blocks for the same input resolution?
Or
Ile
| Posted: Fri Dec 03, 2010 12:07 pm Post subject: |
Check if it's possible to get same picture width for 16:9 and wider formats from your source, so that only picture height chance. Test other AR settings from source menu settings. Don't know popcorn, so can't give straight answer how to do that. Maybe it's now on some auto setting and 16:9 setting should fix that.
Making alternative memory block to projector is also possible. If you now have made adjustments to input 5, press 95 and you can adjust other geometry to this new block.
opv
| Posted: Fri Dec 03, 2010 12:17 pm Post subject: |
The second option you mentioned is exactly what I mean.
What do you press 95, the numbers 9 & 5 in the BARCO remote?
And how do I toggle between the two states?
opv
| Posted: Fri Dec 03, 2010 12:21 pm Post subject: |
OK,
I think I got the idea with the 95, that's exactly what I needed. thanks a lot!
Or
